Here is an updated version of my Find and Delete Spatially Duplicate Records in a Shapefile. This code works in ArcGIS 10.1+ and does not require and advance license, it works on any feature class, and it runs much faster relying on geometry and not selections.
The geometry compare only uses X and y and not z values, sorry but the method comes that way from ESRI. There is no consideration of the attribute table but the tool preserves the original FC.
try:
print "Find And Delete Spatially Duplicate Records in a Feature Class..."
print "A Two-Bit Algorithms product\nby Gerry Gabrisch (geraldg@lummi-nsn.gov)"
print "Copy?Right! 2015...Free to hack with with attribution."
import sys, traceback, time
import arcpy
from arcpy import env
env.overwriteOutput = True
#the input FC with duplicate records....
inFC= r"C:\gTemp\Converted_Graphics.shp"
#The output FC that will have duplicate records purged....
outFC = r"C:\gTemp\Converted_GraphicsTEST.shp"
arcpy.CopyFeatures_management(inFC, outFC)
with arcpy.da.SearchCursor(inFC, ["OID@", "SHAPE@"]) as cursor:
for row in cursor:
with arcpy.da.UpdateCursor(outFC, ["OID@", "SHAPE@"]) as cursor2:
dupcount = 0
for row2 in cursor2:
if cursor[1].equals(cursor2[1]):
dupcount +=1
if dupcount >=2:
dupcount = 1
cursor2.deleteRow()
except arcpy.ExecuteError:
print "error"
msgs = arcpy.GetMessages(2)
arcpy.AddError(msgs)
print msgs
except:
print "error"
tb = sys.exc_info()[2]
tbinfo = traceback.format_tb(tb)[0]
pymsg = "PYTHON ERRORS:\nTraceback info:\n" + tbinfo + "\nError Info:\n" + str(sys.exc_info()[1])
print pymsg + "\n"
