When in the "Data Driven Page Setup" window where you selected the layer to be used as the data driven index, you are able to select a 'Name Field'.
Subsequently, when exporting map, choose the 'Pages' tab, and select the option to export all maps, using a 'name'. When you enter a name into the GUI for your maps, it will then add the name attribute to the end.
For example you enter "Maps_" and it will export "Maps_Map1Name.pdf", Maps_Map2Name.pdf" etc.
