How to Add Field(s) to All shapefiles in a Folder
850
07-09-2012 08:30 AM
BernardoG_
Can you please let me know how I can run an Arcpy script to add field(s) to all shapefiles inside a folder.I already tried this script but it did'nt I am encountering with Error
ExecuteError: Failed to execute. Parameters are not valid. ERROR 000732: Input Table: Dataset Point.shp does not exist or is not supported Failed to execute (AddField).
import arcpy
import os
dirAd = "D:\GIS\Test"
fieldName1 = "ref_ID"
fieldPrecision = 9
fieldAlias = "refcode"
fieldName2 = "status"
fieldLength = 10
for files in os.listdir(dirAd):
    if files.endswith(".shp"):
       arcpy.AddField_management(files, fieldName1, "LONG", fieldPrecision, "", "",fieldAlias, "NULLABLE")
       arcpy.AddField_management(files, fieldName2, "TEXT", "", "", fieldLength)
SolomonPulapkura
Don't use os.listdir. Theres a built in arcpy function for listing shapefiles
do this -
import  arcpy  inFolder = r"D:\GIS\Test"  arcpy.env.workspace = inFolder  l = arcpy.ListFeatureClasses() for i in l:     arcpy.AddField_management(i, "xyz", "TEXT")
SolomonPulapkura
do this -
markdenil
Are you sure Point.shp is a valid shapefile? It could be just a .shp
Is it only that file that hangs it?
BernardoG_
Thanks SolomonP,
it works perfect now
