How to copy all records from a Map/Feature Service
3547
12-16-2016 10:33 AM
PatrickMcKinney1
Occasional Contributor III
I have heard that there is a way to copy all records from a map/feature service to a geodatabase feature class, even if the max record count set for the service is less than the total records in the dataset.
Does anyone know how to do this? Or could anyone help point me in the right direction?
Patrick
FrankPrice
New Contributor III
PatrickMcKinney1
Thanks for the link to the tool.
JayantaPoddar
MVP Esteemed Contributor
fnprice‌,
Thank you for sharing. The above tool by Jake Skinner‌ looks very promising.
Another (traditional) alternative. If you have a license of ArcGIS Desktop and the feature service has EXPORT option enabled, you could just add the service to ArcMap/ArcCatalog/ArcGIS Pro and Export Data to a geodatabase Feature Class.
Think Location
PatrickMcKinney1
Thanks for the tip!
BlakeTerhune
MVP Regular Contributor
Here are some resources I found helpful
ArcGIS REST API
Quick Tips: Consuming Feature Services with Geoprocessing | ArcGIS Blog
Here's the code I put together to do a simple data download. Note, this was tested with 10.2.2, which does not support resultOffset and resultRecordCount request parameters for pagination so you will be limited to 1000 records at a time.
import arcpy
import urllib
def main():
    svc_lyr_url = "http://somedomain.com/arcgis/rest/services/MapServiceName/MapServer/0"
    where_clause = "objectid<100"  ## Required
    field_names = ""  ## Optional "FIELD1,FIELD2,FIELD3"
    # Test availability of service
    try:
        svc_lyr_response = urllib.urlopen(svc_lyr_url)
        print svc_lyr_response
        if svc_lyr_response.getcode() == 200:  ## The request has succeeded
            # Build and format query url
            query_url = "{}/query?where={}&outFields={}&returnGeometry=true&f=json".format(
                svc_lyr_url,
                where_clause,
                field_names,
            try:
                query_response = urllib.urlopen(query_url)
                print query_response
                if query_response.getcode() == 200:  ## The request has succeeded
                    print "http code {} from {}".format(svc_lyr_response.getcode(), query_response.geturl())
                    # Load JSON data from query and copy to feature class
                    fs = arcpy.FeatureSet()
                    fs.load(query_url)
                    arcpy.env.overwriteOutput = True  ## Optional
                    arcpy.CopyFeatures_management(fs, r"C:\temp\TEMP.gdb\SampleDownload")
                    print arcpy.GetMessages()
                else:
                    response_msg = "http code {} from {}".format(
                        query_response.getcode(),
                    raise Exception(response_msg)
            finally:
                query_response.close()
        else:
                svc_lyr_response.geturl()
    finally:
        svc_lyr_response.close()
if __name__ == '__main__':
    main()‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
