How do I install pywin32 for ArcGIS Pro 3.0? It worked for me in 2.x, but in 3.0, the installation fails whether trying it from the Pro user interface (Settings > Package Manager > Add Packages) or in a Python command prompt using conda install or pip install. There seems to be a lot of conflicts in dependency versions. After attempting to install, if I run this code:
from win32com import client
I get:
ImportError: DLL load failed while importing pythoncom: The specified procedure could not be found.
I'm using pywin32 and arcpy to update an APRX and an Excel file and export sheets from Excel to PDF.
The solution I found:
Now I can use pywin32. That last step was a tip I gleaned from Gohlke's wheel page.
This was done on a virtual machine. On my physical machine, the admins have some security thing going on that prevents me from installing the pywin32 package, but others may not encounter such an issue.
Your attempts to install what is already there (at least parts of it) may have had undesireable consequences.
dir(client)
['CDispatch', 'CLSIDToClass', 'CastTo', 'CoClassBaseClass', 'Constants',
'Dispatch', 'DispatchBaseClass', 'DispatchEx', 'DispatchWithEvents', 'EventsProxy', 'GetActiveObject', 'GetObject', 'Moniker', 'Record',
'VARIANT', 'WithEvents', '_PyIDispatchType', '__WrapDispatch', '__builtins__', '__cached__', '__doc__', '__file__', '__loader__',
'__name__', '__package__', '__path__', '__spec__', '_event_setattr_',
'_get_good_object_', '_get_good_single_object_', 'build', 'constants',
'dynamic', 'gencache', 'getevents', 'pythoncom', 'pywintypes', 'sys']
Delete your clone (or reinstall Pro if you tried this in base.
>>>conda install xxxxxx --dry-run
Is a useful step to anticipate installation issues beforehand.
I was working in a clone. I switched back to base (arcgispro-py3) and get this in a Python command prompt.
(arcgispro-py3) C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3>python
Python 3.9.11 [MSC v.1931 64 bit (AMD64)] :: Anaconda, Inc. on win32
Type "help", "copyright", "credits" or "license" for more information.
File "<stdin>", line 1, in <module>
ModuleNotFoundError: No module named 'win32com'
I'm in Pro 3.0.0. Is it possible that attempting to install pywin32 in the clone corrupted the base installation?
I am using 3.0.2.
I can't remember when pywin32 stuff appeared.
Messing with the clone can't affect the base environment.
You can also look at
Welcome to PyPDF2 — PyPDF2 documentation
xlrd — xlrd 2.0.1 documentation
xlwt documentation — xlwt 1.3.0 documentation
for other options if you can resolve, they are installed by esri and I think used somewhere in the Pro ecosystem.
Thanks for the other things to look at but I don't think they handle exporting PDFs from Excel.
With a clean install of Pro 3.0, I upgraded to 3.0.2, and I still don't have pywin32 installed. A search for "win" in the Package Manager in Pro reveals these libraries that seem close but not quite it:
* python-certifi-win32
* pywin32-security
For an import test, this time I tried from within a Python console window in Pro. I get "No module named 'win32com'". I wonder how you have pywin32 but I don't.
