How to reference Map document parameter in ArcGIS Pro?
1535
08-08-2016 05:39 AM
JohnSolly1
New Contributor II
I am trying to save the following python script as a tool to be incorporated into modelbuilder within Pro:
mxd = arcpy.mapping.MapDocument(r"C:\Project\Project.mxd")
arcpy.mapping.ExportToPNG(mxd, r"C:\Project\Output\Project.png")
It works in ArcMap but I'm not sure how to do it in Pro since it does not use .mxd files.
How can I access the map document in Pro and run a tool that traditionally uses an .mxd?
JakeSkinner
Esri Esteemed Contributor
Hi John,
ArcGIS Pro works with projects (.aprx).  You can import your current MXD to a blank aprx.  Ex:
aprx = arcpy.mp.ArcGISProject(r"C:\Projects\blank.aprx")
aprx.importDocument(r"C:\Projects\YosemiteNP\Documents\Yosemite.mxd")
You can then export the layout to PNG:
Layout—ArcPy | ArcGIS for Desktop
RebeccaStrauch__GISP
Jake, for some reason I'm getting an error on you link.
thus might be what you were going for  Export a map or layout—ArcGIS Pro | ArcGIS for Desktop
JakeSkinner
Thanks, Rebecca.  I went ahead and added it manually.
DanPatterson_Retired
apparently linked to modelbuilder too Reference .mxd parameter in ArcGIS Pro's modelbuilder?
