How to require info or editor in arcpy
3672
9
08-19-2015 03:38 AM
GuidoStein
New Contributor III
i have a script that edits sde and requires info or an editor license.
I know that you can use
import arcinfo
or
import arceditor
but if you have two imports, one will fail. So how do you use this pattern to require one or the other?
Thanks in advance for your help.
WesMiller
Regular Contributor III
import arcpy
import arcinfo
if arcinfo:
     print 'info license'
else:
     import arceditor
     if arceditor:
          print 'editor license'
Luke_Pinner
MVP Regular Contributor
Wes, this won't work because a license is checked out when arcpy is imported which defaults to highest available (arcinfo if one is available, arceditor if not, or arcview if all else fails).  You need to import arcview/arceditor/arcinfo before arcpy.
Like this:
import arceditor
import arcpy
print arcpy.ProductInfo()
ArcEditor
Not like this:
import arcpy
import arceditor
ArcInfo
WesMiller
Luke thanks i didn't know that. Does that mean then that it should be a try except so if he doesn't get the upper level licenses it won't run?
class LicenseError(Exception):
    pass
import arcpy
try:
    if arcpy.ProductInfo() == 'ArcInfo' or arcpy.ProductInfo() == 'ArcEditor':
        pass
    else:
        # Raise a custom exception
        raise LicenseError
    print 'Do your work here'
except LicenseError:
    print "ArcInfo or ArcEditor license unavailable"
except:
    print arcpy.GetMessages(2)
GuidoStein
New Contributor III
ok, here is what I wrote up as a standalone check prior to arcpy:
import arcview
if arcview:
  print 'arcview license is available'
else:
  import arceditor
  if arceditor:
  print 'arceditor license is available'
  else:
  import arcinfo
  if arcinfo:
  print 'arcinfo license is available'
  else:
  print 'no license is available'
import arcpy
GuidoStein
New Contributor III
Thanks for this...
XanderBakker
Esri Esteemed Contributor
Please be aware that a bug has been reported for 10.3 and in 10.3.1 this has still not been fixed. See:
import arceditor does not set proper license level
If you have an older version (like 10.1) it will work (not sure if 10.2 works).
Luke_Pinner
Xander, I'm using 10.2.2 and it works. Did you find a workaround in 10.3?
DanPatterson_Retired
Still open....
http://support.esri.com/en/bugs/nimbus/role/beta10_1/QlVHLTAwMDA4NDI0Ng==
​no posted workaround (except a single use license...which is not an option for some)
XanderBakker
As Dan Patterson mentions it is still open en there is no fix available. No workaround unless you want to use single use or separate a license on another server. Thanks for posting that it works in 10.2.2. Apparently it was introduced in 10.3. Might enlist for the 10.4 beta that will soon be around to see if it is fixed...
