how to use GPFeatureRecordSetLayer?
410
07-26-2023 06:00 PM
AzinSharaf
Occasional Contributor II
I've created a python toolbox in ArcGIS Pro and one of the tools uses GPFeatureRecordSetLayer. It creates an interactive mode so user can insert a point on a map.
The problem is when i insert a point the name of the tool will be chosen as layer name in Table of Content  (see screenshot below). How can i control that text value?
param1 = arcpy.Parameter(displayName="Pour Point",
                         name="lyrPourPoint",
                         datatype="GPFeatureRecordSetLayer",
                         parameterType="Required",
                         direction="Input")
param1.filter.list = ["Point"]
param1.symbology = os.path.join(rootFolder, "symbology", "PourPoint.lyrx")
param1.value = os.path.join(rootFolder, "symbology", "PourPoint.lyrx")
by Anonymous User
Not applicable
What is the full code for that toolbox? Could you share it?
