I need the name of the current MXD (newbie question)
4224
07-14-2011 02:52 AM
BobMijwaard
New Contributor III
I have followed the Python course very recently and just finished my first script. To make it more generic I need to know the name of the current MXD
In the script I use:
mxd = arcpy.mapping.MapDocument("CURRENT")
How can I get the name of the used mxd. Tried os.path.basename(mxd) but that did not work. Got the error: MapDocument is unsubscriptable
Regards,
Bob
AndrewChapkowski
The reason you cannot get the path is because mxd is an object, not a string path.  To get the path, you need to use the filePath property on the MapDocument object.
import os
import arcpy
mapPath = mxd.filePath
fileName = os.path.basename(mapPath)
print fileName
If your map document isn't saved, you will get returned an empty string.
BobMijwaard
New Contributor III
Thanks a lot.
Still learning.......
Regards,
Bob
