Similarly, you can get XMin, Ymax, etc. from the Describe Dataset Extent object:import arcpy
# Create a Describe object from the shapefile
desc = arcpy.Describe("C:/data/centerlines.shp")
# Print dataset properties
print "Dataset Type: " + desc.datasetType
extent = desc.Extent
print "Extent:"
print " %s: %f, %s: %f, %s: %f, %s: %f" % ("XMin", extent.XMax, "XMax", extent.XMax,
"YMin", extent.YMin, "YMax", extent.YMax)
print "MExtent: " + desc.MExtent
print "ZExtent: " + desc.ZExtent
SR = desc.spatialReference
print SR.name
