I'm trying to run this script against our federated Portal to add basemaps for offline. The only way I can seem to access our Portal (I've tested in jupyter notebook) without SSL errors thru python is if I include the "verify_cert=False" parameter.
Can someone please show me how to modify the "prepareEsriBasemapsForOfflineUse.py" python script such that the certificate errors are ignored? Like where exactly I should insert the "verify_cert=False" parameter below (python noob here). I seem to recall not having this problem on one of our older servers with this script, maybe one that wasn't https...
Thanks in advance!
IOError: [Errno socket error] [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:661)
import urllib
import json
import argparse
def generateToken(username, password, portalUrl):
'''Retrieves a token to be used with API requests.'''
parameters = urllib.urlencode({'username' : username,
'password' : password,
'client' : 'referer',
'referer': portalUrl,
'expiration': 60,
'f' : 'json'})
response = urllib.urlopen(portalUrl + '/sharing/rest/generateToken?',
parameters).read()
try:
jsonResponse = json.loads(response)
if 'token' in jsonResponse:
return jsonResponse['token']
elif 'error' in jsonResponse:
print jsonResponse['error']['message']
for detail in jsonResponse['error']['details']:
print detail
except ValueError, e:
print 'An unspecified error occurred.'
print e
def searchPortal(portal, query=None, totalResults=None, sortField='numviews',
sortOrder='desc', token=''):
Search the portal using the specified query and search parameters.
Optionally provide a token to return results visible to that user.
allResults = []
if not totalResults or totalResults > 100:
numResults = 100
else:
numResults = totalResults
results = __search__(portal, query, numResults, sortField, sortOrder, 0,
token)
if not 'error' in results.keys():
if not totalResults:
totalResults = results['total']
allResults.extend(results['results'])
while (results['nextStart'] > 0 and
results['nextStart'] < totalResults):
numResults = min(totalResults - results['nextStart'] + 1, 100)
results = __search__(portal=portal, query=query,
numResults=numResults, sortField=sortField,
sortOrder=sortOrder, token=token,
start=results['nextStart'])
return allResults
else:
print results['error']['message']
return results
def __search__(portal, query=None, numResults=100, sortField='numviews',
sortOrder='desc', start=0, token=None):
'''Retrieve a single page of search results.'''
params = {
'q': query,
'num': numResults,
'sortField': sortField,
'sortOrder': sortOrder,
'f': 'json',
'start': start
if token:
params['token'] = token
request = portal + '/sharing/rest/search?' + urllib.urlencode(params)
results = json.loads(urllib.urlopen(request).read())
return results
def groupSearch(query, portalUrl, token=''):
'''Search for groups matching the specified query.'''
parameters = urllib.urlencode({'q': query, 'token': token, 'f': 'json'})
request = (portalUrl + '/sharing/rest/community/groups?' + parameters)
groups = json.loads(urllib.urlopen(request).read())
return groups['results']
def getUserContent(username, portalUrl, token):
parameters = urllib.urlencode({'token': token, 'f': 'json'})
request = (portalUrl + '/sharing/rest/content/users/' + username +
'?' + parameters)
print request
content = urllib.urlopen(request).read()
return json.loads(content)
def getItemDescription(itemId, portalUrl, token=''):
'''Returns the description for a Portal for ArcGIS item.'''
parameters = urllib.urlencode({'token' : token,
'f' : 'json'})
response = urllib.urlopen(portalUrl + "/sharing/rest/content/items/" +
itemId + "?" + parameters).read()
return json.loads(unicode(response, 'utf-8'))
def createFolder(username, title, portalUrl, token):
'''Creates a new folder in a user's content.'''
parameters = urllib.urlencode({'title': title,
'token' : token,
'f' : 'json'})
response = urllib.urlopen(portalUrl + '/sharing/rest/content/users/' +
username + '/createFolder?', parameters).read()
return json.loads(response)
def addServiceItem(username, folder, description, serviceUrl, portalUrl,
token, thumbnailUrl='', serviceUsername=None,
servicePassword=None):
'''Creates a new item in a user's content.'''
descriptionJSON = __decodeDict__(json.loads(description))
parameters = {'item': descriptionJSON['title'],
'url': serviceUrl,
'thumbnailurl': thumbnailUrl,
'overwrite': 'false',
'token' : token,
'f' : 'json'}
if serviceUsername and servicePassword:
parameters.update({'serviceUsername': serviceUsername,
'servicePassword': servicePassword})
parameters.update(descriptionJSON)
postParameters = urllib.urlencode(parameters)
username + '/' + folder + '/addItem?',
postParameters).read()
def __decodeDict__(dct):
newdict = {}
for k, v in dct.iteritems():
k = __safeValue__(k)
v = __safeValue__(v)
newdict[k] = v
return newdict
def __safeValue__(inVal):
outVal = inVal
if isinstance(inVal, unicode):
outVal = inVal.encode('utf-8')
elif isinstance(inVal, list):
outVal = __decode_list__(inVal)
return outVal
def __decode_list__(lst):
newList = []
for i in lst:
i = __safeValue__(i)
newList.append(i)
return newList
if __name__ == '__main__':
parser = argparse.ArgumentParser()
parser.add_argument('-u', '--portal', required=True,
help=('url of the Portal (e.g. '
'https://portal.domain.com:7443/arcgis)'))
parser.add_argument('-o', '--portalAdmin', required=True,
help='Portal admin username')
parser.add_argument('-s', '--portalPassword', required=True,
help='Portal admin password')
parser.add_argument('-a', '--agoAdmin', required=True,
help='ArcGIS Online admin username')
parser.add_argument('-p', '--agoPassword', required=True,
help='ArcGIS Online admin password')
parser.add_argument('-f', '--folder', required=False,
help='Optional destination folder')
args = parser.parse_args()
agoAdmin = args.agoAdmin
agoPassword = args.agoPassword
portal = args.portal
portalAdmin = args.portalAdmin
portalPassword = args.portalPassword
folderTitle = args.folder
print 'Getting token for ' + portal
token = generateToken(username=portalAdmin, password=portalPassword,
portalUrl=portal)
folderId = ''
if folderTitle == None:
print 'Using the root folder...'
folderId = '/'
else:
userContent = getUserContent(portalAdmin, portal, token)
for folder in userContent['folders']:
if folder['title'] == folderTitle:
folderId = folder['id']
if folderId == '':
print 'Creating folder ' + args.folder + '...'
newFolder = createFolder(portalAdmin, folderTitle, portal, token)
folderId = newFolder['folder']['id']
print 'Using folder ' + folderTitle + ' (id:' + folderId + ')'
query = 'owner:esri title:Tiled Basemaps'
sourceGroup = groupSearch(query, 'https://www.arcgis.com')[0]['id']
basemaps = searchPortal('https://www.arcgis.com', 'group:' + sourceGroup)
for basemap in basemaps:
description = getItemDescription(basemap['id'],
serviceUrl = description['url']
thumbUrl = ('https://www.arcgis.com' +
'/sharing/rest/content/items/' + description['id'] +
'/info/' + description['thumbnail'])
newDescription = json.dumps(
{'title': description['title'],
'type': description['type'],
'snippet': description['snippet'],
'description': description['description'],
'licenseInfo': description['licenseInfo'],
'tags': ','.join(description['tags']),
'typeKeywords': ','.join(description['typeKeywords']),
'accessInformation': description['accessInformation']}
try:
result = addServiceItem(portalAdmin, folderId, newDescription,
serviceUrl, portal, token, thumbUrl,
agoAdmin, agoPassword)
if 'success' in result:
print 'Successfully added ' + basemap['title']
elif 'error' in result:
print 'Error copying ' + basemap['title']
print result['error']['message']
for detail in result['error']['details']:
print detail
else:
print 'An unhandled error occurred.'
except:
print 'An unhandled exception occurred.'
print 'Copying complete.'
