import arcpy in multiprocessing make script to hang indefinitely
297
07-24-2019 08:37 AM
MaximeDemers
Occasional Contributor III
I have a simple script to test multiprocessing with arcpy, but the script hang indefinitely. The problem is with the import arcpy statement that seems to be a problem in the child processes. Other multiprocessing script without import arcpy are working correctly
import arcpy
import multiprocessing
import os, sys
multiprocessing.set_executable(os.path.join(sys.exec_prefix, 'python.exe'))
def testExists(data):
    print data
    return arcpy.Exists("foo.gdb")
if __name__ == '__main__':
    data = ["foo.gdb", "bar.gdb"]
    pool = multiprocessing.Pool(2)
    result_arrays = pool.map(testExists, data)
    print result_arrays
    pool.close()
    pool.join()
Any idea what can cause the problem?
Tags (1)
