I get different results from a SetNull operation when I run it in a python script compared to a python toolbox. The inputs are exactly the same and the scripts are the same except one has been converted into a python toolbox.
My input is a raster made up of ones and zeros, I then use SetNull to set the zeros to nulls - I then use RasterToPolygon so I get a shape where all the ones were.
In the python script this runs correctly.
However, in the python toolbox the output of the SetNull initially looks correct but if I go into symbology and turn on 'all other values' I can see that instead of nulls the zeros are either still zero or have value= -128. This means that when the RasterToPolygon runs I get unwanted shapes which screws up the rest of the script.
So my question is - Has anyone else experienced anything like this, is it likely to be a bug in the tool, or could it be my scripting error?
