i have a code that has two issues 1. only one point gets updated with the parcel attributes no other points get updated and 2. the insertRow i currently have does not work it give me .
line 63, in <module>
insCursor.insertRow(row)
TypeError: sequence size must match size of the row
basically i am trying to create multiple points that spatially joins the new created points to parcels and updates the points attributes based on what parcel the points are created i am not sure why i am getting the following error.
I have checked to see if the "point" is being updated by the updatecursor with arcpy.FeatureClassToFeatureClass_conversion(point, "C:\Temp\Default.gdb", "p_lyr") after updateRows.updateRow(updateRow) and it looks like only one point gets updated.Separate question, Can i use the SpatialJoin to "In_memory" instead of to a gdb?I would really appreciate some help please.working with.#import modules
import arcpy
# Allow overwrite
arcpy.env.qualifiedFieldNames = False
# Script user input parameters
pointFC = "CCA
parcel = "Parcels1" #Taxparcels
arcpy.env.workspace = r"C:\Temp\Default.gdb"
parcel_lyr = 'parcel_lyr'
sjpoints = "C:\Temp\Default.gdb\sjpoints"
poly = "ACCOUNT_1"
Pnt = "Account"
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd)[0]
dfsr = df.spatialReference
fcsr = arcpy.Describe(pointFC).spatialReference
if dfsr.name == fcsr.name:
"""Now do your work"""
point = arcpy.GetParameterAsText(0) #click
for prow in arcpy.da.SearchCursor(point,'SHAPE@XY'):
x,y = prow[0]
del prow
point1 = arcpy.Point(x, y)
ptGeometry = arcpy.PointGeometry(point1)
insCursor = arcpy.da.InsertCursor(pointFC,'SHAPE@XY') # create insert cursor
arcpy.MakeFeatureLayer_management(parcel,parcel_lyr)
arcpy.SelectLayerByLocation_management(parcel_lyr,"INTERSECT",point)
#Run the Spatial Join tool, using the defaults for the join operation and join type
arcpy.SpatialJoin_analysis(point, parcel_lyr , sjpoints)
#arcpy.FeatureClassToFeatureClass_conversion(parcel_lyr, "C:\Temp\Default.gdb", "parcel_lyr")
# define the field list from the spatial join
sourceFieldsList = ["TARGET_FID", poly,"SiteAddress",'SiteNum_1', 'SiteStreet_1','SiteStreet_1','SiteNumSfx_1','Predir_1','Postdir_1', 'SiteCity_1', 'SiteZIP_1', 'OwnerName_1']
# define the field list to the original points
updateFieldsList = ["OID@", Pnt,"SiteAddres",'SiteNum','StreetName', 'SiteStreet', 'SiteNumSfx','Predir', 'Postdir', 'SiteCity', 'SiteZip', 'OwnerName']
# populate the dictionary from the polygon
valueDict = {r[0]:(r[1:]) for r in arcpy.da.SearchCursor(sjpoints, sourceFieldsList)}
with arcpy.da.UpdateCursor(point, updateFieldsList) as updateRows:
for updateRow in updateRows:
keyValue = updateRow[0]
if keyValue in valueDict:
for n in range (1,len(sourceFieldsList)):
updateRow
#arcpy.FeatureClassToFeatureClass_conversion(point, "C:\Temp\Default.gdb", "p_lyr")
with arcpy.da.SearchCursor(point,('Account','SiteAddres','SiteNum','StreetName', 'SiteStreet', 'SiteNumSfx','Predir', 'Postdir', 'SiteCity', 'SiteZip', 'OwnerName')) as cursor: # loop through feature set
for row in cursor:
row = []
arcpy.RefreshActiveView()
could you format your code please, so that people can refer to line numbers...
Posting Code blocks in the new GeoNet
For some weird reason it lets me format the code to python when i first posted but noticed that it was just plain text after i posted, i tried to go edit my first post and it seems like it will let me format the text to python but when i hit post it goes back to plan text.
#import modules
import arcpy
# Allow overwrite
pointFC = "CCA
poly = "ACCOUNT_1"
Pnt = "Account"
x,y = prow[0]
del prow
updateRow
for row in cursor:
row = []
edited by Xander Bakker, formated code
Odd... tried to edit the post by the OP, shows formatted code, but once saved it turn normal italic text...
#import modules import arcpy # Allow overwrite arcpy.env.overwriteOutput = True arcpy.env.qualifiedFieldNames = False # Script user input parameters pointFC = "CCA parcel = "Parcels1" #Taxparcels arcpy.env.workspace = r"C:\Temp\Default.gdb" parcel_lyr = 'parcel_lyr' sjpoints = "C:\Temp\Default.gdb\sjpoints" poly = "ACCOUNT_1" Pnt = "Account" mxd = arcpy.mapping.MapDocument("CURRENT") df = arcpy.mapping.ListDataFrames(mxd)[0] dfsr = df.spatialReference fcsr = arcpy.Describe(pointFC).spatialReference if dfsr.name == fcsr.name: """Now do your work""" point = arcpy.GetParameterAsText(0) #click for prow in arcpy.da.SearchCursor(point,'SHAPE@XY'): x,y = prow[0] del prow point1 = arcpy.Point(x, y) ptGeometry = arcpy.PointGeometry(point1) insCursor = arcpy.da.InsertCursor(pointFC,'SHAPE@XY') # create insert cursor arcpy.MakeFeatureLayer_management(parcel,parcel_lyr) arcpy.SelectLayerByLocation_management(parcel_lyr,"INTERSECT",point) #Run the Spatial Join tool, using the defaults for the join operation and join type arcpy.SpatialJoin_analysis(point, parcel_lyr , sjpoints) #arcpy.FeatureClassToFeatureClass_conversion(parcel_lyr, "C:\Temp\Default.gdb", "parcel_lyr") # define the field list from the spatial join sourceFieldsList = ["TARGET_FID", poly,"SiteAddress",'SiteNum_1', 'SiteStreet_1','SiteStreet_1','SiteNumSfx_1','Predir_1','Postdir_1', 'SiteCity_1', 'SiteZIP_1', 'OwnerName_1'] # define the field list to the original points updateFieldsList = ["OID@", Pnt,"SiteAddres",'SiteNum','StreetName', 'SiteStreet', 'SiteNumSfx','Predir', 'Postdir', 'SiteCity', 'SiteZip', 'OwnerName'] # populate the dictionary from the polygon valueDict = {r[0]:(r[1:]) for r in arcpy.da.SearchCursor(sjpoints, sourceFieldsList)} with arcpy.da.UpdateCursor(point, updateFieldsList) as updateRows: for updateRow in updateRows: keyValue = updateRow[0] if keyValue in valueDict: for n in range (1,len(sourceFieldsList)): updateRow= valueDict[keyValue][n-1] updateRows.updateRow(updateRow) #arcpy.FeatureClassToFeatureClass_conversion(point, "C:\Temp\Default.gdb", "p_lyr") with arcpy.da.SearchCursor(point,('Account','SiteAddres','SiteNum','StreetName', 'SiteStreet', 'SiteNumSfx','Predir', 'Postdir', 'SiteCity', 'SiteZip', 'OwnerName')) as cursor: # loop through feature set for row in cursor: row = [] insCursor.insertRow(row) arcpy.RefreshActiveView()
so... posted the code here and applied the formatting. I do wonder if lines 18 and 19 are correct? Could you confirm this please?
I am making sure that i am in the same spatial reference with the following.
Yes, that's the point, then the code starting from line 20 should be indented...
As Xander Bakker says...your logic is flawed and the code needs to be indented...
>>> if "a" == "b": ... print("Now do your work") ... else: ... print("it just carries on anyway") ... Now do your work >>> if "a" == "b": ... print("Now do your work") ... else: ... print("it just carries on anyway") ... it just carries on anyway >>>
not the subtle but oh so important difference in logic
This looks like a problem to me.
with arcpy.da.SearchCursor(point,('Account','SiteAddres','SiteNum','StreetName', 'SiteStreet', 'SiteNumSfx','Predir', 'Postdir', 'SiteCity', 'SiteZip', 'OwnerName')) as cursor: for row in cursor: row = [] insCursor.insertRow(row)
You're trying to insert an empty row. I think you need the same number of values in the row list as there are fields in the cursor. If you're trying to just insert a blank row, fill the values with nulls (or defaults if nulls not allowed). Maybe something like this?
row = [ None, ## Account None, ## SiteAddres None, ## SiteNum None, ## StreetName None, ## SiteStreet None, ## SiteNumSfx None, ## Predir None, ## Postdir None, ## SiteCity None, ## SiteZip None ## OwnerName ]
I have tried the following and both give me errors.
with arcpy.da.SearchCursor(point,('Account','SiteAddres','SiteNum','StreetName', 'SiteStreet', 'SiteNumSfx','Predir', 'Postdir', 'SiteCity', 'SiteZip', 'OwnerName')) as cursor: # 'POINT_X', 'POINT_Y','SHAPE@XY'# loop through feature set for row in cursor: row =[ None, #Account None, #SiteAddres None, #SiteNum None, #StreetName None, #SiteStreet None, #SiteNumSfx None, #Predir None, #Postdir None, #SiteCity None, #SiteZip None,#OwnerName ] insCursor.insertRow(row)
error
AND
with arcpy.da.SearchCursor(point,('Account','SiteAddres','SiteNum','StreetName', 'SiteStreet', 'SiteNumSfx','Predir', 'Postdir', 'SiteCity', 'SiteZip', 'OwnerName')) as cursor: # 'POINT_X', 'POINT_Y','SHAPE@XY'# loop through feature set for row in cursor: row [0] = row[0] #Account row [1] = row[1] #SiteAddres row [2] = row[2] #SiteNum row [3] = row[3] #StreetName row [4] = row[4] #SiteStreet row [5] = row[5] #SiteNumSfx row [6] = row[6] #Predir row [7] = row[7] #Postdir row [8] = row[8] #SiteCity row [9] = row[9] #SiteZip row [10] = row[10] #OwnerName insCursor.insertRow(row)
error
TypeError: 'tuple' object does not support item assignment
You cannot change values with a SearchCursor, only access them. You would need an UpdateCursor if you were setting values.
