Hey everyone,The following is the first thing that my script does after setting up variables etc...# Create Fishnet
desc = gp.describe (streams)
xmin = desc.extent.xmin
ymin = desc.extent.ymin
xmax = desc.extent.xmax
ymax = desc.extent.ymax
origin_coord = str (xmin) + " " + str(ymin)
y_axis_coord = str (xmin) + " " + str(ymin + 10)
corner_coord = str (xmax) + " " + str(ymax)
gp.CreateFishnet_management ("Fishnet.shp", origin_coord, y_axis_coord, 0, 0, 2, 2, corner_coord, "NO_LABELS", "")
# Convert the Fishnet to Polygon
gp.FeatureToPolygon_management("Fishnet.shp", "FishnetPoly.shp", "#", "NO_ATTRIBUTES", "")
# Calculate ID Field with Incremental number
gp.CalculateField_management("FishnetPoly.shp", "id", "autoIncrement()", "PYTHON_9.3", "rec=0\\ndef autoIncrement():\\n global rec\\n pStart = 1 #adjust start value, if req'd \\n pInterval = 1 #adjust interval value, if req'd\\n if (rec == 0): \\n rec = pStart \\n else: \\n rec = rec + pInterval \\n return rec")
# Add and Calculate Text Field (SplitField) With That Same Number
gp.AddField_management("FishnetPoly.shp", "SplitField", "TEXT", "#", "#", 1, "", "NULLABLE", "NON_REQUIRED", "")
gp.CalculateField_management("FishnetPoly.shp", "SplitField", '"id"', "VB", "")
# Loop Through Each FishnetPoly Cell and Select Those Catchments That Have Their Center In The Given Cell
for i in range (1,5,1):
### Make Feature Layer From First Fishnet Cell
gp.MakeFeatureLayer_management ("FishnetPoly.shp", "FishnetCell", '"SplitField" = ' + str(i), gp.Workspace, "")
### Make Feature Layer From Catchments
gp.MakeFeatureLayer_management (catchments, "CatchmentsLayer", "", gp.Workspace, "")
### Select Catchments Which Have Their Center in the Feature Layer Cell
gp.SelectLayerByLocation_management ("CatchmentsLayer", "HAVE_THEIR_CENTER_IN", "FishnetCell")
It returns the following error at gp.SelectLayerByLocation_management...ExecuteError: ERROR 999999: Error executing function.
An invalid SQL statement was used.
A locator with this name does not exist.
Failed to execute (SelectLayerByLocation).
I have no idea why. I don't know what SQL statement it could be referring to.Any ideas?
