Using Python 2.7.8, I'm trying to use the default field mappings for all fields except for 2 (PIC_ID and Object ID). The two tables are essentially identical, the tinkering with the globalid is something I have to do in order to preserve the globalid part of an attachment relationship when syncing an AGOL feature service to an on-premise SDE, and not something I'm looking to change. The below snippet works when I'm just altering one field out of the mapping:
target_layer = "C:/blah blah blah.sde/blah.DBO.blah"
append_layer = renamefgdb+'\yada_yada_yada'
fieldmappings = arcpy.FieldMappings()
fieldmappings.addTable(target_layer)
fieldmappings.addTable(append_layer)
field_to_map_index = fieldmappings.findFieldMapIndex("globalid")
field_to_map = fieldmappings.getFieldMap(field_to_map_index)
field_to_map.addInputField(append_layer, "PIC_ID")
fieldmappings.replaceFieldMap(field_to_map_index, field_to_map)
arcpy.Append_management(append_layer, target_layer, "NO_TEST", fieldmappings, "")
However I have an operational requirement to maintain the objectid during append: that is, the objectID's coming from the append source need to be the same when they go to the target layer.
But when I do something like this, or many many many variations thereof, it fails.
field_to_map_index = fieldmappings.findFieldMapIndex("objectid")
field_to_map.addInputField(append_layer, "OBJECTID")
So is it possible to add ObjectID to a field mapping in python, and if so, how?
