Issues with spatial reference object from currently active map
1413
01-27-2023 07:11 AM
SeanConway
I'm having an arcpy issue where I'm trying to pull a spatial reference object from the currently active map to use to create a point geometry.  It works fine if I pull it from the first layer in the ToC:
insr = arcpy.Describe(layers[0]).spatialReference
But if I pull it from the currently active map:
aprx = arcpy.mp.ArcGISProject("CURRENT")
m = aprx.listMaps()[0]
insr = m.spatialReference
then I get an error. Both the layer and the map return a spatial reference object, but when I use the one from the map, it ends up erroring out on this line:
point1 = arcpy.PointGeometry(arcpy.Point(extent.XMin,extent.YMin),insr)
  File "<string>", line 12, in <module>
  File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\arcobjects\geometries.py", line 86, in __init__
    super().__init__(inputs, spatial_reference, has_z, has_m)
  File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\arcobjects\mixins.py", line 223, in __init__
    self._arc_object = gp.CreateObject('geometry', self.__type_string__,
  File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 512, in <lambda>
    return lambda *args: val(*gp_fixargs(args, True))
  File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 43, in gp_fixargs
    new_args.append(gp_fixarg(arg, string_results, pass_arc_object))
  File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 30, in gp_fixarg
    if isinstance(arg, Result) and string_results:
RuntimeError: SpatialReference: Get attribute __class__ does not exist
The attached images are an example of the object it's returning where insr is the SR object from a layer and insr2 is the object from the map. They are different projections but that shouldn't be an issue.  If I use exportToString() on the map object and then use that to loadFromString() on a new SR object then it will also work, but that seems like a needless workaround.
Thanks in advance for any help.
JohannesLindner
MVP Frequent Contributor
Yeah, sometimes arcpy can be tricky with the conversion between Result objects, geoprocessing xyz objects and the "pure" xyz objects.
In this case, you can just create a new SpatialReference with the factory code of your extracted sr:
m = arcpy.mp.ArcGISProject("current").activeMap
extent = m.defaultCamera.getExtent()
map_sr = m.spatialReference
map_point = arcpy.PointGeometry(arcpy.Point(extent.XMin,extent.YMin), map_sr)  # error
map_sr = arcpy.SpatialReference(map_sr.factoryCode)
map_point = arcpy.PointGeometry(arcpy.Point(extent.XMin,extent.YMin), map_sr)  # works
Have a great day!
Johannes
