Hello all,
I will try to summarize this as best as possible. I am essentially looking to join survey data to a shapefile! shouldn't be so hard..but I have been left stumped as to why the Join tool is leading me to duplicated rows. I've tried Dissolving the data on the repeated values (such as Shape_Area) but I lose all the columns from the survey data in the output - did another join to the newly dissolved output and again missing data.
For reference, the shapefile row count is 104 and the csv of the survey data is 178 rows. So essentially I want to do a 1-many match on the unique identifier, in my example which is responde (essentially respondent id). I thought about maybe doing this in Pandas but it doesn't look like arcpy and pandas are friends yet but I found one of @DanPatterson's suggestions here.
Following his instructions I think the arcpy.da.ExtendTable function could work well however, I'm not well versed with numpy and I'm having problems setting up my column names, or as numpy calls them "dtype".
The example ESRI provides is pretty basic with just three values in the array, whereas my csv is 178 rows with quite a lot of data. I have been trying to pass on the dtype names + format with no success.
ESRI Example:
This is my code
# df = the csv of survey data
df2 = df[['respondent,C,254', 'category', 'value', 'value_cat', 'unique_ID']]
array = df2.to_records()
print(array)
# apply the dtype attribute
result = df2.dtypes
print("Output:")
print(result)
# try to create a dictionary of my column names this step may be redundant because I have the result variable above
# dts = {'names': ('Unnamed: 0','respondent,C,254','category', 'value', 'value_cat', 'unique_ID'),
# 'formats':(numpy.int64, numpy.object, numpy.object, numpy.object, numpy.object,
# numpy.int64)}
array_table = numpy.rec.fromrecords(array, dtype=dts)
# Convert array to a geodatabase table
table = filepath + '\\table_test'
#check that this is a valid filepath
print(table)
arcpy.da.NumPyArrayToTable(array_table, table)
# Append the array to an existing table on responde (shp) to respondent,c,254(csv)
arcpy.da.ExtendTable(cultural_shp, "responde", array, "respondent,C,254")
These are my errors - have I not formatted my array correctly?
Many thanks in advance!
