I need some help with batch processing using python. I am trying to join fields to multiple point features classes from multiple dbf tables (650 feature classes and tables). Names of the dbf tables match names from each feature class. I have got the script so far; I am not sure where I went wrong as the script runs but feature classes are not updated with the join. I am using arcpy.joinField.management instead of Add Join because I want to update the feature classes directly without having to create feature layer and save. If this where I am wrong, please let me know.
Any help is highly appreciated. My script so far is below:
import arcpy, os
from arcpy import env
# Add variables
GDB1 = r"C:\test\GDB1.gdb"
GDB2 = r"C:\test\GDB2.gdb"
joinField = "Work_ID"
env.workspace = GDB1
#Join tables
for fc in arcpy.ListFeatureClasses():
env.workspace = GDB2
for table in arcpy.ListTables():
try:
if table() == fc():
try:
arcpy.JoinField_management(GDB1 + os.sep + fc, joinField, GDB2 + os.sep + table, joinField, "")
except:
arcpy.AddMessage("Could not join ")
pass
except:
pass
