List Feature Classes within Subfolders using Python
8525
01-06-2011 07:16 AM
TomJansen
I'm trying to get a list of feature classes in a folder and it's subfolders.  Below is a script that gets just the folder specified.  Any help on how to loop through the subfolders is appreciated.
import arcpy
from arcpy import env
import os
# Set the workspace for the ListFeatureClass function
env.workspace = "C:/Data"
# Use the ListFeatureClasses function to return a list
fcList = arcpy.ListFeatureClasses()
print fcList
JasonScheirer
Regular Contributor II
You could use a generator in this case:
import arcpy
import os
def fcs_in_workspace(workspace):
  arcpy.env.workspace = workspace
  for fc in arcpy.ListFeatureClasses():
    yield os.path.join(workspace, fc)
  for ws in arcpy.ListWorkspaces():
    for fc in fcs_in_workspace(os.path.join(workspace, ws)):
        yield fc
for fc in fcs_in_workspace("C:/Data"):
Or you could do something like
fclist = list(fcs_in_workspace("C:/Data"))
and reuse it.
JasonScheirer
import arcpy
import os
    print os.path.join(workspace, fc)
ChristinaHerrick1
How would you then iterate through the list later in the script?
Ex. "for fc in fclist: ..."
JasonScheirer
import arcpy
import os
        yield fc
and reuse it.
ChristinaHerrick1
Awesome!  Thanks!
JeffBigos
Hi All,
I wanted to add to additional ways to accomplish this and apply it to different data types.
I teach Python for Esri and have had this question come up in class alot.
1. Arcpy.da.walk:
     This was introduced to the data access module at 10.1 SP1
     ArcGIS Help (10.2, 10.2.1, and 10.2.2)
     Where this function is nice is in 2 parameters
     Datatype: the value set here is the filter for what is returned as walk traverses the subfolders
     type: not for all datasets, but at least you could specify point, line, poly or raster types
     Look at the Sample script 1 in the documentation
2. python os.walk:
     this function will perform the same type operation gathering subfolders and files
     The one difference is this won't retrieve contents inside of a geodatabase.
     This could be used if you script involved python code with out the use of arcpy
     maybe you needed to find all the .xls files under a D:\projects folder.
     15.1. os — Miscellaneous operating system interfaces — Python 2.7.8 documentation
Jeff
