ListFields returning blanklist
5371
42
07-26-2016 02:26 PM
BlakeBarr
Hi Everyone, I am trying to convert dbf to csv using the following code:
import arcpy
import os
import csv
def DBFtoCSV(path):
    '''Convert every DBF table into CSV table.
    arcpy.env.workspace = path
    tablelist=arcpy.ListTables('*', 'dBASE')
    for table in tablelist:
        outputFile = '{}.csv'.format(table.split('.dbf')[0])
        # Get the fields in the dbf to use for the cursor and csv header row.
        fields = []
        for field in arcpy.ListFields(table):
            fields.append(str(field.name))
# Make the csv.
        with open((os.path.join(path,outputFile)),'wb') as output:
            dataWriter = csv.writer(output, delimiter=',', quotechar='"', quoting=csv.QUOTE_MINIMAL)
    # Write header row.
            dataWriter.writerow(fields)
    # Write each row of data to the csv.
            with arcpy.da.SearchCursor(table, fields) as cursor:
                for row in cursor:
                    dataWriter.writerow(row)
        print('Finished creating {}'.format(outputFile))
if __name__ == '__main__':
    path=r'F:\DataLocation'
    DBFtoCSV(path)
I am getting an error at the SearchCursor because it says field names must be string or non empty. I added the print statement and it turns out my list of fields is empty. Can anyone tell me why this is?
BlakeBarr
Okay Thanks. Right now I can only open them in OpenOffice. once I figure out how to access ArcMap at my institution(new job) I will get back to you, but that is very helpful.
BlakeBarr
Hey Dan,
Just I just loaded the file into ArcMap. Was able to view it alright, but two fields with dates got wiped and every obs was <NULL> instead of the date.
XanderBakker
Esri Esteemed Contributor
Are the .dbf files part of shapefiles? In case this is true those will not be found by arcpy.ListTables .
I just did a test on local my machine with the slightly altered code:
import arcpy
import os
import csv
def DBFtoCSV(path):
    tablelist = arcpy.ListTables('*', 'dBASE')
    for table_name in tablelist:
        outputFile = '{}.csv'.format(table_name.split('.dbf')[0])
        table = os.path.join(path, table_name)
        print table
        fields = [fld.name for fld in arcpy.ListFields(table)]
        print fields
        # Make the csv.
        with open((os.path.join(path, outputFile)), 'wb') as output:
            # Write header row.
                for row in cursor:
                    dataWriter.writerow(list(row))
    # path = r'F:\DataLocation'
    path = r'D:\Temp\test'
    DBFtoCSV(path)
and it printed:
D:\Temp\test\myTable1.dbf
[u'OID', u'OBJECTID', u'COD_DIV_TE', u'COD_PAIS', u'NOM_DIV_TE', u'SHAPE_Leng', u'SHAPE_Area']
Finished creating myTable1.csv
D:\Temp\test\myTable2.dbf
[u'OID', u'OBJECTID', u'COD_DIV_TE', u'NOM_DIV_TE', u'COD_DIV_SU', u'AREA_KM', u'SHAPE_Leng', u'SHAPE_Area']
Finished creating myTable2.csv
Conversion worked, but my shapefile in that folder was not converted. You should in that case list the featureclasses in that folder.
BlakeBarr
Thanks Xander,
I am not sure how to check if they are part of shape files to be honest. Is there a way to check that?
BlakeBarr
import dbf
import arcpy
import os
import csv
def DBFtoCSV(path):
    print path
    #tablelist=arcpy.ListTables('*', 'dBASE')
    tables = arcpy.ListFeatureClasses('*.shp')
    tables.extend(arcpy.ListTables('*', 'dBASE'))
    print tables
    for table in tables:
        print table
        fields = []
        for field in arcpy.ListFields(os.path.join(path,table)):
            fields.append(field.name)
        print fields
# Make the csv.
    # Write header row.
                for row in cursor:
    path='F:/Datalocation'
    DBFtoCSV(path)
I added the list feature classes using code I found but am getting the same problem.
BlakeBarr
Not sure if this sheds any light on the issue
but when I try to use
def DBFtoCSV(path):
    print tables
    print tables
        print table
        outputFile = '{}.xls'.format(table.split('.dbf')[0])
        arcpy.TableToExcel_conversion(table, outputFile)
    path='F:/DataLocation'
    DBFtoCSV(path)
I get an error that says that the dbf file cannot be opened. When I did not get that before. Just trying different approaches in the hopes that I can find one that works haha
XanderBakker
Sounds like the data might be corrupt. Can you include the prints of the code (the tables list twice) to see what it finds?
BlakeBarr
Yup. I also just recieved permission from my supervisor to share the directory. Here is the code
import arcpy
import os
import csv
def DBFtoCSV(path):
    print tables
    print tables
        print table
        fields = []
# Make the csv.
 # Write header row.
                for row in cursor:
    path='F:/FERC/raw_data/eqr_transaction_2009/EQRDATA'
    DBFtoCSV(path)
Here is the error:
C:\>python dbf_convert_stack2.py
First print: []
Second print: [u'EQR_TRANSACTION_200903_AL.dbf', u'._EQR_TRANSACTION_200903_AL.dbf', u'EQR_TRA
NSACTION_200903_MZ.dbf', u'._EQR_TRANSACTION_200903_MZ.dbf', u'eqr_transaction_2
00903.dbf', u'._eqr_transaction_200903.dbf', u'EQR_TRANSACTION_200906_AL.dbf', u
'._EQR_TRANSACTION_200906_AL.dbf', u'EQR_TRANSACTION_200906_MZ.dbf', u'._EQR_TRA
NSACTION_200906_MZ.dbf', u'eqr_transaction_200906.dbf', u'._eqr_transaction_2009
06.dbf', u'eqr_transaction_200909_388.dbf', u'._eqr_transaction_200909_388.dbf',
u'EQR_TRANSACTION_200909_AL.dbf', u'._EQR_TRANSACTION_200909_AL.dbf', u'EQR_TRA
NSACTION_200909_MZ.dbf', u'._EQR_TRANSACTION_200909_MZ.dbf', u'eqr_transaction_2
00909.dbf', u'._eqr_transaction_200909.dbf', u'eqr_transaction_200912_388.dbf',
u'._eqr_transaction_200912_388.dbf', u'EQR_TRANSACTION_200912_AL.dbf', u'._EQR_T
RANSACTION_200912_AL.dbf', u'EQR_TRANSACTION_200912_MZ.dbf', u'._EQR_TRANSACTION
_200912_MZ.dbf', u'eqr_transaction_200912.dbf', u'._eqr_transaction_200912.dbf']
Third Print: EQR_TRANSACTION_200903_AL.dbf
  File "dbf_convert_stack2.py", line 39, in <module>
    DBFtoCSV(path)
  File "dbf_convert_stack2.py", line 30, in DBFtoCSV
TypeError: 'field_names' must be string or non empty sequence of strings
My end goal is to import these into STATA, so CSV or Excel doesn't really matter. Just trying anything that may work. It's weird that I get a cannon open error with the Tableto Excel  but not here.
XanderBakker
Could you post the entire code (which generates the error). Now it seems you posted part of the code and the errors refer to the wrong lines. I also notice that you are trying to convert to Excel now, but still use the dbf output name.
BlakeBarr
Just updated above. Thanks for your help.
