I recently switched from Desktop to Pro and have run into a problem with locks being left on shapefiles when I use SelectLayerByAttribute or SelectLayerByLocation. Both the Desktop and Pro documentation show the same stand-alone script for both tools, though the Pro version of the script is a bit different.
DESKTOP:
env.workspace = "c:/data/mexico.gdb"
# Make a layer from the feature class
arcpy.MakeFeatureLayer_management("cities", "lyr")
# Select all cities which overlap the chihuahua polygon
arcpy.SelectLayerByLocation_management("lyr", "intersect", "chihuahua", 0, "new_selection")
PRO:
arcpy.env.workspace = 'c:/data/mexico.gdb'
chihuahua_cities = arcpy.SelectLayerByLocation_management('cities', 'INTERSECT', 'chihuahua', 0, 'NEW_SELECTION')
The Desktop sample shows using MakeFeatureLayer to create a feature layer out of the cities feature class, then passing that as the first argument to the SelectLayerByLocation tool. The Pro sample doesn't bother to create a feature layer first; it simply plugs in the feature class ('cities'). The Pro sample also shows storing a returned object in a variable (chihuahua_cities).
When I've used these tools on shapefiles in Desktop, I've always used MakeFeatureLayer as shown in the sample. It places a lock on the shapefile, but I can remove the lock by using Delete when I'm done (in this case, I'd do arcpy.Delete_management("lyr")).
When I try to follow the syntax shown in the Pro help (storing the returned object in a variable), I also get a lock placed on the shapefile, but I haven't found a way to remove the lock aside from closing my IDE. I've tried:
arcpy.Delete_management(chihuahua_cities)
arcpy.Delete_management(chihuahua_cities[0])
But neither actually removes the lock. I can continue to code it the way that's shown in the Desktop help, but was wondering if there was a fix to the problem that follows the syntax shown in the Pro help.
Thanks!
