loop down through a directory tree.
8306
19
07-02-2014 09:01 AM
PaulHuffman
Occasional Contributor III
I want to loop through a folder and clip all feature classes by a AOI poly and write the results to an output folder.  How to I also have the loop search all subfolders for vectors and raster feature classes as well?
BruceNielsen
You could use a list comprehension on line 8 to create a full path to each of the rasters:
rasterList.append([os.path.join(arcpy.env.workspace, A) for A in arcpy.ListRasters("*", "GRID")])
PaulHuffman
That produces an error "TypeError: 'NoneType' object is not iterable"   What does that mean?  Is the "*" the 'NoneType'?
PaulHuffman
I'm about ready to tell the client that we're going to run this in ArcGIS 10.2.  da.Walk makes this so easy.  This script uses da.walk and handles the tifs and grids in the tree, except I hit one grid that had a file name so long I couldn't add any extra letters.
#testcliprasterda.py
#test trying to walk a directory tree, find rasters and shapefiles, and clip to a area of Interest (AOI)
# using da.walk first available at ArcGIS 10.1
# Paul Huffman, Yakama Fisheries, 7/7/2014
# Import arcpy module
import arcpy
import os
#arcpy.CheckOutExtension("spatial")
# Set Geoprocessing environments
arcpy.env.scratchWorkspace = "c:\\avdata\\PythonTest\\ClipLidar\\Scratch"
#arcpy.env.workspace = "c:\\avdata\\PythonTest\\ClipLidar\TestData"
arcpy.env.workspace = "c:\\avdata\\PythonTest\\ClipLidar\\TestData\\Input\\Highest_Hit"
arcpy.env.overwriteOutput = True
clipshape = "c:\\avdata\\PythonTest\\ClipLidar\\AOIPoly_SP.shp"
InputFolder = "c:\\avdata\\PythonTest\\ClipLidar\\TestData\\Input"
#InputFolder = "c:\\avdata\\PythonTest\\ClipLidar\\TestData\\Input\\Highest_Hit"
#OutputFolder = "c:\\avdata\\PythonTest\\ClipLidar\\TestData\\Output"
#Find AOI extent
AOI = arcpy.mapping.Layer(clipshape)
AOIextent=AOI.getExtent()
#rasterList=[]
#Find the input feature classes
#for root, dirs, files in os.walk(InputFolder):
#walk = arcpy.da.Walk(InputFolder, topdown=True, datatype="RasterDataset")
for root, dirs, files in arcpy.da.Walk(InputFolder, topdown=True, datatype="RasterDataset"):
    for name in files:
        FileObj = arcpy.mapping.Layer(os.path.join(root, name))
        FileExtent = FileObj.getExtent()
        print "Processing: " + name
       #if image overlap or touches AOI polygon,  then clip image, write to output
        Extent_Disjoint = str(FileExtent.disjoint(AOIextent))
        if Extent_Disjoint == 'False':
            print "Clipping: " + name
            OutputPath = root.replace("Input","Output")
            if not os.path.exists(OutputPath):
                os.makedirs(OutputPath)
            #Handle tifs
            if os.path.splitext(name)[1] == ".tif":
                Clipname = os.path.splitext(name)[0] + "cp.tif"
            else:
                #Clipname = os.path.splitext(name)[0] + "c"
            print "Writing " + (os.path.join(OutputPath,Clipname))
            arcpy.Clip_management((os.path.join(root, name)),"#",(os.path.join(OutputPath,Clipname)),clipshape,"#","ClippingGeometry")
BruceNielsen
What that probably means is that the list was empty; no GRIDs in the folder. You may need to make it a little smarter:
rasterInDir = arcpy.ListRasters("*", "GRID")
if len(rasterInDir) > 0:
    rasterList.append([os.path.join(arcpy.env.workspace, A) for A in rasterInDir])
PaulHuffman
I'm starting to get confused.  Using Bruce's last code, now I'm getting subdirectories to my InputFolder added to my rasterList.  And I'm missing the last slash in the path name on all of them.  Grids are only found in C:\avdata\PythonTest\ClipLidar\TestData\Input\Highest_Hit
>>> ================================ RESTART ================================
c:\avdata\PythonTest\ClipLidar\TestData\InputHighest_Hit
c:\avdata\PythonTest\ClipLidar\TestData\InputOrthophotos
c:\avdata\PythonTest\ClipLidar\TestData\Inputvectors
c:\avdata\PythonTest\ClipLidar\TestData\Input\Highest_Hitellen_n_hh
c:\avdata\PythonTest\ClipLidar\TestData\Input\Highest_Hithillsha_elle1
c:\avdata\PythonTest\ClipLidar\TestData\Input\Highest_Hitinfo
c:\avdata\PythonTest\ClipLidar\TestData\Input\Highest_Hitmt_clifty_hh
c:\avdata\PythonTest\ClipLidar\TestData\Input\Highest_Hitraven_hh
c:\avdata\PythonTest\ClipLidar\TestData\Input\Highest_Hittaneum_hh
c:\avdata\PythonTest\ClipLidar\TestData\Input\Highest_Hitteanaway_hh
c:\avdata\PythonTest\ClipLidar\TestData\Input\Highest_Hity5012010-2000
PaulHuffman
Less confused now.  What I was seeing was the output of the first print statement, unnoticed at first, now commented out, but it showed me that I needed to add '\\" into the string.  Now I'm getting a rastList that I can work with:
rasterList=[]
    for targetdir in dirs:
        #print root + "\\" + targetdir
        targetworkspace = root + "\\" + targetdir
        arcpy.env.workspace = targetworkspace
        #rasterList.append (arcpy.ListRasters("*", "GRID"))
        if rasterInDir > 0:
for raster in rasterList:
        print raster, "\n"
PaulHuffman
I'm still confused.  It looks like my full path rasters are in the list twice, along with some [] elements.
    print raster
[u'c:\\avdata\\PythonTest\\ClipLidar\\TestData\\Input\\Highest_Hit\\ellen_n_hh', u'c:\\avdata\\PythonTest\\ClipLidar\\TestData\\Input\\Highest_Hit\\hillsha_elle1', u'c:\\avdata\\PythonTest\\ClipLidar\\TestData\\Input\\Highest_Hit\\mt_clifty_hh', u'c:\\avdata\\PythonTest\\ClipLidar\\TestData\\Input\\Highest_Hit\\raven_hh', u'c:\\avdata\\PythonTest\\ClipLidar\\TestData\\Input\\Highest_Hit\\taneum_hh', u'c:\\avdata\\PythonTest\\ClipLidar\\TestData\\Input\\Highest_Hit\\teanaway_hh', u'c:\\avdata\\PythonTest\\ClipLidar\\TestData\\Input\\Highest_Hit\\y5012010-2000']
[u'c:\\avdata\\PythonTest\\ClipLidar\\TestData\\Input\\Highest_Hit\\ellen_n_hh\\ellen_n_hh']
[u'c:\\avdata\\PythonTest\\ClipLidar\\TestData\\Input\\Highest_Hit\\hillsha_elle1\\hillsha_elle1']
[u'c:\\avdata\\PythonTest\\ClipLidar\\TestData\\Input\\Highest_Hit\\mt_clifty_hh\\mt_clifty_hh']
[u'c:\\avdata\\PythonTest\\ClipLidar\\TestData\\Input\\Highest_Hit\\raven_hh\\Band_1']
[u'c:\\avdata\\PythonTest\\ClipLidar\\TestData\\Input\\Highest_Hit\\taneum_hh\\taneum_hh']
[u'c:\\avdata\\PythonTest\\ClipLidar\\TestData\\Input\\Highest_Hit\\teanaway_hh\\teanaway_hh']
[u'c:\\avdata\\PythonTest\\ClipLidar\\TestData\\Input\\Highest_Hit\\y5012010-2000\\y5012010-2000']
PaulHuffman
I got this version that is working for Grids.  But it will bomb if it finds a second folder under the input starting point containing grids.  I'm detecting  grids with by looping through workspaces and adding grids to the list if the number of grids counted is > 0,  lines 28 to 34.  But the folder above the Grids is always included in this list,  so I delete it out again with line 38.  Very crude!
#testclipgrids.py
#test trying to walk a directory tree, find grids, and clip to a area of Interest (AOI)
# and make it run in 10.0 so without da.walk.
# Paul Huffman, Yakama Fisheries, 7/14/2014
import arcpy
import os
#arcpy.env.workspace = "c:\\avdata\\PythonTest\\ClipLidar\\TestData\\Input\\Highest_Hit"
#Find AOI extent
#Intialize empty lists
rasterList=[]
rasterList1=[]
            rasterList.append(arcpy.env.workspace)
        print raster
del rasterList[0]
#start comparing extents and clipping
for name in rasterList:
    FileObj = arcpy.mapping.Layer(name)
        foldername = os.path.dirname(name)
        OutputPath = foldername.replace("Input","Output")
        #print "name = " +name
        #print "OutputPath =" + OutputPath
        Clipbasename = os.path.basename(Clipname)
        #print "Clipname = " + Clipname
        print "Writing " + (os.path.join(OutputPath,Clipbasename))
        arcpy.Clip_management(name,"#",(os.path.join(OutputPath,Clipbasename)),clipshape,"#","ClippingGeometry")
PaulHuffman
There is still something wrong with the way arcpy.ListRasters works to detect grids.  Maybe not wrong, but unexpected.  Line 12's output shows that ListRasters still finds my grids in their parent workspace and also the subdirectory for the grid that contains the info external files.
The code segment:
#Find the input  Grid feature classes
            for raster in rasterInDir:
                rasterList.append(targetworkspace + "\\" + raster)
        print raster
The output of the print statement, in part:
c:\avdata\PythonTest\ClipLidar\TestData\Input\BareEarth\hillsha_tane1
c:\avdata\PythonTest\ClipLidar\TestData\Input\BareEarth\hillsha_tane1\hillsha_tane1
PaulHuffman
Fixed it.  This is what satisfied the colleague, and was put into production. Lines 30-34 is how I check to see if the current worksheet is a Grid or a workspace containing grids.  Had to go through this extra BS because I couldn't use da.walk.
#testclipgridstifsshapes.py
# Paul Huffman, Yakama Fisheries, 7/21/2014
import arcpy
import os
#arcpy.env.scratchWorkspace = "c:\\avdata\\PythonTest\\ClipLidar\\Scratch"
#find input folder bottom folder
InputString = InputFolder.split("\\")[-1]
#Find AOI extent
rasterList=[]
        #if the targetworkspace can be initialized as a Raster object, do nothing else
        try:
            arcpy.Raster(targetworkspace)
         #if the targetworkspace fails when an attempt is made to initialize it as a raster object, search for rasters within it
        except:
##for raster in rasterList:
##        print raster
    #print "Processing: " + name
        OutputPath = foldername.replace(InputString,"Output")
        if len(os.path.basename(name)) > 10:
            Shortname = (os.path.basename(name))[0:11]
            print "Grid name shortened to " + Shortname
            Clipname = os.path.splitext(Shortname)[0] + "cp"
        else:
            Clipname = os.path.splitext(name)[0] + "cp"
#Find the input tifs and shapefiles
    for name in files:
                OutputPath = root.replace(InputString,"Output")
        #for shapefiles, use a different clip, write to output.
        if os.path.splitext(name)[1] == ".shp":
            print(os.path.join(root, name))
                arcpy.Clip_analysis((os.path.join(root, name)),clipshape,(os.path.join(OutputPath,Clipname)))
