My python script calculates only the value of the immediate previous record
2683
10
04-26-2016 11:26 AM
OLANIYANOLAKUNLE
Occasional Contributor II
My python script calculates only the value of the immediate previous record instead of calculating the values of all preceding records before that particular record. The example (the image) below is the undesired output;
While the image below here is what i want to achieve;
This is my python script i used;
import arcpy
from arcpy import da
CensusBldForm = "CensusBldForm"
Calculated_EA1=0
with arcpy.da.UpdateCursor(CensusBldForm, ["OBJECTID", "EstimatedPopulationinEA", "Calculated_EA"]) as cursor:
     for row in cursor:
          Calculated_EA2 = row[1]
          row[2] = (Calculated_EA1 + Calculated_EA2)
          Calculated_EA1 = Calculated_EA2
          cursor.updateRow(row)
Kindly assist me with the above please.
Tags (1)
WesMiller
Regular Contributor III
Change this line
To this
Calculated_EA1 += Calculated_EA2
WesMiller
Change this line
To this
OLANIYANOLAKUNLE
Thanks, it worked like magic
WesMiller
That's great! Please remember to mark your question as answered
OLANIYANOLAKUNLE
My edits don't get saved after running the script, because i have to start an edit session before running the script;
        Calculated_EA1=0
            for row in cursor:
What do you think might be wrong or better still can i get it to run without starting an edit session i.e using a arcpy.UpdateCursor instead of arcpy.da.UpdateCursor? Thanks
OLANIYANOLAKUNLE
This is the error message i get when i want to save edits;
Kindly assist me please. Thanks in advance
DanPatterson_Retired
a wild guess that you aren't doing this on a file stored on your local machine but from sde or some other thing like that.  That error message has a history... there are some suggestion which you can search on geonet and narrow down the issue.  This is just one of several
https://community.esri.com/message/551258#comment-551258
OLANIYANOLAKUNLE
Thanks, i'm actually running my script against an SDE Geodatabase
OLANIYANOLAKUNLE
Thanks i changed from the default version to another version and i didn't get any error and my edits where retained as well.
that is bad to hear from the threads... good luck
