Hi all,
I am working on a script that transforms the vertex coordinates of input multi-part polygon shapefiles and outputs these transformed coordinate values into new multi-part polygons. When I run the script, I am able to generate an identical shapefile to the original (but with transformed coordinate values), but none of the individual features remain. I've tried to debug the code myself by observing the format of my main array that is fed into the arcpy.Polygon object and compared these results against arrays from working script examples provided by ESRI. I don't see any difference, but clearly something is not right. I was hoping someone could have a look below and recommend a solution. Here's the code:
import arcpy
import math
infc = "C:\\testing\\fortesting.shp"
def transform(pntX,pntY):
global Calc_north
global Calc_east
global Calc_elev
start_north = -3770671.323
start_east = -72160.677
end_north = -3770648.576
end_east = -72151.373
delta_n = start_north - end_north
delta_e = end_east - start_east
angle = math.degrees(math.atan(delta_n/delta_e))
deltaY = pntX*(math.sin(math.radians(angle)))
deltaX = pntX*(math.cos(math.radians(angle)))
Calc_north = start_north - deltaY
Calc_east = deltaX + start_east
Calc_elev = pntY
array = arcpy.Array()
# Enter for loop for each feature
for row in arcpy.da.SearchCursor(infc, ["OID@", "SHAPE@"]):
# Print the current multipoint's ID
print("Feature {}:".format(row[0]))
# Step through each part of the feature
for part in row[1]:
# Step through each vertex in the part
sub_array = arcpy.Array()
for pnt in part:
# Print x,y coordinates of current point
transform(pnt.X,pnt.Y)
#print pnt.X, pnt.Y, Calc_east, Calc_north, Calc_elev
new_pnt = arcpy.Point(Calc_east, Calc_north)
sub_array.add(new_pnt)
sub_array.add(sub_array.getObject(0))
array.add(sub_array)
del sub_array
multi_Part_Polygon = arcpy.Polygon(array, arcpy.SpatialReference(102484), True)
arcpy.CopyFeatures_management(multi_Part_Polygon,"C:\\testing\\test18.shp")
