New to Python
1313
13
03-14-2023 12:46 PM
ChrisGlenn
I am having trouble with a file path or the format of the destination I believe. I am very new to Python and have pieced this together with a lot of questions without a strong understanding of ArcGIS yet.
# Imports
import arcpy
# Workspace
trail_data = r"C:\PythonPro\Final\Trail"
county_data = r"C:\PythonPro\Final\Counties\Oregon_Counties.shp"
# Get a list of unique county names
counties = []
with arcpy.da.SearchCursor(county_data, "County_Name") as cursor:
    for row in cursor:
        if row[0] not in counties:
            counties.append(row[0])
# Print the list of counties and ask the user to choose one
print("Choose a county: ")
for i, county in enumerate(counties):
    print(f"{i+1}. {county}")
selection = int(input("> ")) - 1
selected_county = counties[selection]
print("Measuring...")
# Use the selected county to clip the trail data
clip_output = "C:/data/clipped_trails.shp"
where_clause = f"County_Name = '{selected_county}'"
arcpy.Clip_analysis(trail_data, county_data, clip_output, where_clause)
# Calculate the total distance of bike trails in the clipped data
total_distance = 0
with arcpy.da.SearchCursor(clip_output, "SHAPE@LENGTH") as cursor:
    for row in cursor:
        total_distance += row[0]
# Display the total distance to the user
print(f"The total distance of bike trails in {selected_county} is {total_distance:.2f} meters.")
The error code I am getting is: RuntimeError: Cannot find field 'County_Name'
I have tried to change the source and the configuration of the files on my PC. I suspect that the problem is something simple that I am missing, but I am banging my head against a wall and can't see it clearly. Any help is appreciated. Thanks.
Chris
2 Solutions
Mahdi_Ch
I think since it is not obvious that what type of file you are reading (shape file, geodatabase, etc) it is not easy to go further in troubleshooting as that might be the initial issue.
Then the second issue might be the field (column header) name that you are passing does not exist.  You can check for that like this:
fields = arcpy.ListFields(country_data)  # list of objects
field_names = [i.name for i in fields]  # list of field names
#check if 'Country_Name' is in the list of names
# instead of one field name you can also pass a list of them.
if 'County_Name' in field_names:
    counties = []
        for row in cursor:
else:
     print('County_Name not in the fields')
DavidPike
MVP Frequent Contributor
Line 17 doesn't make much sense.  the error is probably coming from your search cursor.  Are you sure county_name exists in the data rather than being some result of a join on layer object?  Are you also sure county_name is the field name rather than an alias?
DavidPike
Please format your code for readability, it's also lost its indentation.  https://community.esri.com/t5/python-blog/code-formatting-the-community-version/ba-p/1007633
Do you know what line it's erroring on? that would save a lot of debugging time.  Perhaps comment out each section and run it sequentially uncommenting lines to see where the error is.
##what is trail data? Looks like a workspace/folder but you're using it as a clip input?
trail_data = r"C:\PythonPro\Trail"
ChrisGlenn
# Imports
import arcpy
# Workspace
counties = []
    for row in cursor:
total_distance = 0
    for row in cursor:
ChrisGlenn
Apologies for the incorrect format. Here is what I have. I've tried to download the layer I am using as a .shp and .gdb and have had similar issues.
Line 17 is where the error code comes from.
DavidPike
DanPatterson
Code formatting ... the Community Version - Esri Community
"county_data"  is a folder, so if it is a geodatabase, then you need to provide the gdb name and the featureclassname.  If it is a shapefile you need the *.shp
eg  county_data = r"C:\PythonPro\Counties.gdb\MyFeatureclass"
... sort of retired...
Mahdi_Ch
    counties = []
        for row in cursor:
else:
Mahdi_Ch
By the way , assuming the 'County_Name' exists, if you are looping to get the unique values of that field, there is a faster (at least faster to write) cleaner Pythonic way, by using set.
A set is an unordered collection with no duplicate elements. So basically,  instead of going line by line and assigning the values after checking if they already exist, you can use a "set comprehension" to add all the values to the set function. And then Python set() do the work behind the scene and returns only the unique values for you.
    # extracting unique values in the field using Python set function and set comprehension
    counties= sorted({row[0] for row in cursor})
Then the sorted function -obviously- sorts the values and returns them in a list.
Please follow what @DavidPike  sent you to make your code readable.
DavidPike
@Mahdi_Ch  I think it would be useful if you explained in the code comments the logic of writing to a set,  would be a good thing to understand for beginners.
Mahdi_Ch
David, you are totally right. I edited my post and included the comments.  Thank you for mentioning that.
