Hi
I try to specify an argument for output shape file to create it (outputShape = sys.argv[4])
and to get the shape file name from parameters. Then I set the output file parameter as a feature class and output. But my output parameter doesn't work. the script is as follows.
Why Cannot I get the output name from parameters?
# the path to workplace arcpy.env.workspace = sys.argv[1] # The path to the CSV file inputCSVfile = sys.argv[2] #Get the template shapefile templateShapeFile = sys.argv[3] # The name of the output shape file outputShape = sys.argv[4] <<<-------------------------------------------------- Here???? it doesn't work,Why??? # open CSV file inFile = open(inputCSVfile, "r") # create feature class arcpy.CreateFeatureclass_management(arcpy.env.workspace, outputShape, "POINT", templateShapeFile, "DISABLED", "DISABLED", templateShapeFile)
The second parameter of the arcpy.CreateFeatureclass_management function should be a string and not a Feature Class
Great help, Thank you
I changed the parameter value to string and it worked.
Best
