I have been using a python script for about a month now that does this for me. All of a sudden it is not working. It gets 3/4ths the way through and gives me this error while attempting to overwrite:
File "C:\GIS\scripts\Updating_Web_Layer_Tool_Updated.py", line 138, in <module>
fs = sdItem.publish(overwrite=True)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py", line 15139, in publish
serviceitem_id = self._check_publish_status(ret, folder)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py", line 15499, in _check_publish_status
raise Exception("Job failed.")
Exception: Job failed.
I am not quite sure what it is asking me to do. Any suggestions. Here is the script:
import arcpy
import os, sys
from arcgis.gis import GIS
prjPath = r"C:\example\Test.aprx"
sd_fs_name = “Feature_Class_Name”
portal = "https://test.com/portal/"
user = "test@user"
password = "password"
shrOrg = True
shrEveryone = False
shrGroups = ""
relPath = r"C:\example\examples"
sddraft = os.path.join(relPath, "WebUpdate.sddraft")
sd = os.path.join(relPath, "WebUpdate.sd")
print("Creating SD file...")
prj = arcpy.mp.ArcGISProject(prjPath)
mp = prj.listMaps()[0]
arcpy.mp.CreateWebLayerSDDraft(map_or_layers=mp,
out_sddraft=sddraft,
service_name=sd_fs_name,
server_type="HOSTING_SERVER",
service_type="FEATURE_ACCESS",
folder_name=None,
overwrite_existing_service=True,
copy_data_to_server=True)
arcpy.StageService_server(in_service_definition_draft=sddraft,
out_service_definition=sd)
print("Connecting to {}".format(portal))
gis = GIS(portal, user, password)
print("Search for original SD on portal...")
sdItem = gis.content.search("{} AND owner:{}".format(sd_fs_name, user), item_type="Service Definition")[0]
print("Found SD: {}, ID: {} n Uploading and Overwriting...".format(sdItem.title, sdItem.id))
sdItem.update(data=sd)
print("Overwriting existing feature service...")
if shrOrg or sheEveryone or sheGroups:
print("Setting sharing options...")
fs.share(org=shrOrg, everyone=shrEveryone, groups=shrGroups)
print("Finished updateing: {} - ID: {}".format(fs.title, fs.id))
