I have the following for loop which subsets 420 DEM's into 20 DEM's.:
for i in range(0,420,21):
low = i
high = i + 21
interval = high / 21
AK_in = 'str_dems_AK' + str(interval)
AK_out = 'NED_AK' + str(interval)
subset_AK = AK_in + ' = str_dems_AK[' + str(low) + ':' + str(high) + ']'
exec subset_AK
arcpy.MosaicToNewRaster_management(AK_in, r"H:\dmf\pds\ned\grid\raster_mosaics", AK_out, "", "", "", "1", "", "")
arcpy.BuildPyramids_management(AK_out, "", "", "", "", "", "SKIP_EXISTING")
which results in the following error:
File "H:\NED_BuildPyramids_Mosaic_test.py", line 85, in <module>
File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\management.py", line 11619, in MosaicToNewRaster
raise e
ExecuteError: ERROR 000582: Error occurred during execution.
If I manually run the following command it works so I assume the problem is passing the value of “AK_out” into the mosaic command:
arcpy.MosaicToNewRaster_management(AK_in, r"H:\dmf\pds\ned\grid\raster_mosaics",”NED_AK1”, "", "", "", "1", "", "")
If have tried a variety of alternatives but I always get an error so I'm hoping that someone can tell me how to (a) pass the value of AK_out into the mosiac command or (b) if that's not the problem, identify what is causing the eror.
Mike.
