Script created by Chris Snyder; modified by C. Denninger # Script resulted from ESRI Forum posts dated 04FEB2010. # This script is used in a script tool within ArcGIS and calculates #..the median value of one entire field and posts that single median #...value to every row in one other entire field. import sys, arcgisscripting gp = arcgisscripting.create(9.3) inputTable = gp.GetParameterAsText(0) readField = gp.GetParameterAsText(1) #this needs to be a numeric field writeField = gp.GetParameterAsText(2) #this needs to be a double or float valueList = [] searchRows = gp.searchcursor(inputTable) searchRow = searchRows.next() while searchRow: searchRowValue = searchRow.getvalue(readField) if searchRowValue == None: pass #don't add a null value to the list! else: valueList.append(searchRowValue) searchRow = searchRows.next() del searchRow del searchRows valueList.sort() listLength = len(valueList) if listLength == 0: print "Every value was null! Exiting script..."; sys.exit() elif listLength % 2 == 0: #even, so get the mean of the 2 center values medianValue = (valueList[listLength / 2] + valueList[listLength / 2 - 1]) / 2.0 else: #odd, so it's easy! medianValue = valueList[listLength / 2] updateRows = gp.updatecursor(inputTable) updateRow = updateRows.next() while updateRow: updateRow.setvalue(writeField, medianValue) updateRows.UpdateRow(updateRow) updateRow = updateRows.next() del updateRow del updateRows
import arcpy, sys, os inputTable = arcpy.GetParameterAsText(0) readField = arcpy.GetParameterAsText(1) writeField = arcpy.GetParameterAsText(2) valueList = [] searchRows = arcpy.da.SearchCursor(inputTable) searchRow = searchRows.next() while searchRow: searchRowValue = searchRow.getValue(readField) if searchRowValue == None: pass #don't add a null value to the list! else: valueList.append(searchRowValue) searchRow = searchRows.next() del seachRow del searchRows valueList.sort listLength = len(valueList) if listLength == 0: print "Every value was null! Exiting script..."; sys.exit() elif listLength % 2 == 0: #even, so get the mean of the 2 center values medianValue = (valueList[listLength / 2] + valueList[listLength / 2 - 1]) / 2.0 else: medianValue = valueList[listLength / 2] updateRows = arcpy.da.UpdateCursor(inputTable) updateRow = updateRows.next() while updateRow: updateRow.setvalue(writeField, medianValue) updateRows.UpdateRow(updateRow) updateRow = updateRows.next() del updateRow del updateRows
Solved! Go to Solution.
Don't forget to Mark a reply as the Correct Answer
