Please post the top portion of your code where you parse out the input parameters.
Sorry, which part are you talking about? The execute() method?# ~~ execute() ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #
def execute(self, P, messages):
EXECUTE() calls ImpactScoreRasters.ImpactScoreRasters in Bungee's
executing directory.
pK = self.paramOrder
import arcpy
# process parameters
analysis = arcpy.Describe(P[pK['analysis']].value).catalogPath
outPad = arcpy.Describe(P[pK['outPad']].value).catalogPath
outRoad = arcpy.Describe(P[pK['outRoad']].value).catalogPath
outPipe = arcpy.Describe(P[pK['outPipe']].value).catalogPath
usePadFootprint = P[pK['usePadFootprint']].value
Or are you referring to the getParameterInfo portion? # ~~ __getParameterInfo__() ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #
def getParameterInfo(self):
"""Define parameter definitions"""
import arcpy
# input analysis object (pickled file)
analysis = arcpy.Parameter(
displayName = 'Analysis Object File',
name = 'analysis',
datatype = 'File',
parameterType = 'Required',
direction = 'Input'
# Output Pad Raster
outPad = arcpy.Parameter(
displayName = 'Output Pad Raster',
name = 'outPad',
datatype= 'Raster Dataset',
direction = 'Output'
# Output Road Raster
outRoad = arcpy.Parameter(
displayName = 'Output Road Raster',
name = 'outRoad',
# Output Pipe Raster
outPipe = arcpy.Parameter(
displayName = 'Output Pipeline Raster',
name = 'outPipe',
# Use Pad Footprint Flag
usePadFootprint = arcpy.Parameter(
displayName = 'Use Pad Footprint?',
name = 'usePadFootprint',
datatype = 'Boolean',
parameterType = 'Optional',
direction = 'Input'
usePadFootprint.value = False
# finish
parameters = [
analysis,
outPad,
outRoad,
outPipe,
usePadFootprint
return parameters
