Primary/Foreign Key from Relationship Class
2405
11-22-2013 11:35 AM
brettangel
Occasional Contributor II
I was able to get the relationshipClassNames property to work (thanks Xander!), but did not realize the relationshipClass property did not have a primary and foreign key field.
arcpy.Describe(arcpy.MakeTableView_management(table, table + "_view")).relationshipClassNames:
I tried using some code from this thread, but get an empty value [].
fields = arcpy.Describe(relationshipName).fields
print fields
Any ideas on how to get the primary/foreign keys from a relationship class?
brettangel
The answer from tech support is the primary/foreign key properties are not exposed in Python, but there is an enhancement request already in for this.
JillianPenney
Brett,
You may have been on one of the other threads where I posted this response, but incase you missed it, this functionality will be included in the 10.2.1 release via arcpy.Describe(<relclass>).OriginClassKeys and arcpy.Describe(<relclass>).DestinationClassKeys.
Jill
brettangel
Thanks Jill!
