pyodbc in ArcGIS Pro
2365
08-10-2018 02:51 PM
KevinBell1
New Contributor III
In ArcGIS Pro, if I use the ability to search for a package to add (pyodbc) it doesn't show up.  Any ideas on how to get this going?
Kev
Tags (3)
DanPatterson_Retired
long story, it isn't installed by default so you will have to 'clone' the distribution in order to install it and have it available for PRO
did you get it working Kevin?
KevinBell1
New Contributor III
Nope!  I hit Manage Environments/Clone and it shows the new env w/ the Active radio button checked and then it say to restart Pro to take effect, but upon restarting there's no clone!  What up?!
XanderBakker
Esri Esteemed Contributor
You might want to check this support page for the problem in creating environments Problem: Unable to create environments or install packages after upgrading to ArcGIS Pro 2.2
Rhys-Donoghue
New Contributor III
In case it helps anyone, I had to run ArcGIS Pro as Administrator, even though the user I was logged in had admin privileges.
