Hi folks,
I'm running into an isse trying to build a python with an Extension Class, to be used to do some logic when a layer is added or removed from the mxd (itemAdded(), itemDeleted() built in functions)
So, I had orginally built a toolbar which included 2 comboboxes and a button and then the Extension Class. I wanted to test how the functions worked, so I left the Extension Class functions as the default coding and just threw in a couple print lines to see if they printed out the message in the python console in Arcmap when I added or removed a layer. The problem I am having is, it keeps throwing an error:
TypeError: unbound method itemAdded() must be called with ExtensionClass instance as first argument (got Layer instance instead) |
I've been pouring through the net, trying to understand what an unbound method is, but I'm still not at a point where I understand how to resolve this error.
I tested again but simply creating a new addin project with one Extension Class and then the 2 fucntions above (itemAdded(), itemDeleted()). I threw a couple print lines in the functions to see if they fired off properly and success.
Further to that, I commented out all of my code in my original script, except the Extension Class (so that it has the exact same code as my test addin), fired up Arcmap and added a layer and it still throws the error.
Can anyone suggest what I am missing?
Test Addin Code (that works)
import arcpy
import pythonaddins
class ExtensionClass(object):
"""Implementation for Addins_addin.ExtensionClass (Extension)"""
def __init__(self):
# For performance considerations, please remove all unused methods in this class.
self.enabled = True
print self
def itemAdded(self, new_item):
print "Added " + new_item.name
pass
def itemDeleted(self, deleted_item):
print "Deleted " + deleted_item.name
pass
Original Code here:
import arcpy
import pythonaddins
cboSetup1 = None
cboSetup2 = None
lyr = None
"""Implementation for Build_Definition_Query_from_Selected_Features_addin.ExtensionClass (Extension)"""
def __init__(self):
self.enabled = True
print self
print "Added"
pass
print "Deleted"
pass
class btn1(object):
"""Implementation for Build_Definition_Query_from_Selected_Features_addin.btn1 (Button)"""
def __init__(self):
mxd = arcpy.mapping.MapDocument("CURRENT")
self.items = []
global lyrDefQueryDict
lyrDefQueryDict = {}
for layer in arcpy.mapping.ListLayers(mxd):
if not layer.isGroupLayer:
self.items.append(layer.name)
lyrDefQueryDict[layer.name] = layer.definitionQuery
print lyrDefQueryDict
self.enabled = True
self.checked = False
def onClick(self):
combo1 = cbobox1
combo1.btnPopulate()
combo1.refresh()
combo2 = cbobox2
combo2.value = ''
combo2.refresh()
if lyr:
for lyrName,lyrDefQuery in lyrDefQueryDict.iteritems():
if lyr.name == lyrName:
print "lyr.name = " + lyr.name
print "lyrName = " + lyrName
print "lyrDef = " + lyrDefQuery
lyr.definitionQuery = lyrDefQuery
arcpy.RefreshActiveView()
class cbobox1(object):
"""Implementation for Build_Definition_Query_from_Selected_Features_addin.cbobox1 (ComboBox)"""
def __init__(self):
self.items = []
global cboSetup1
cboSetup1 = self.items
self.editable = True
self.enabled = True
self.dropdownWidth = 'WWWWWWWWWWWWWWWWWW'
self.width = 'WWWWWWWWWWWWWWWWW'
def onSelChange(self, selection):
if layer.name == selection:
global lyr
lyr = layer
print layer.name
fieldList = [field.name for field in arcpy.ListFields(layer.name)]
global cboSetup2
cboSetup2 = fieldList
cbobox2.updateFields()
def onFocus(self, focused):
self.items = cboSetup1
def btnPopulate(self):
self.value = ''
self.items = []
global cboSetup1
class cbobox2(object):
"""Implementation for Build_Definition_Query_from_Selected_Features_addin.cbobox2 (ComboBox)"""
def __init__(self):
self.enabled = True
self.dropdownWidth = 'WWWWWWWWWWWWWWWWW'
self.items = cboSetup2
selectionList = []
for row in arcpy.SearchCursor(lyr):
selectionList.append(row.getValue(selection))
if len(selectionList) == 1:
lyr.definitionQuery = "{0} = {1}".format(selection,selectionList[0])
else:
lyr.definitionQuery = "{0} in {1}".format(selection,tuple(selectionList))
def updateFields(self):
