# Import ArcPy import arcpy # Set up variables # Location of pole map .mxd document mxdDoc = r"G:\GEOSPATIAL\Publishing\Pole\Pole_QtrSec.mxd" # Create the MapDocument object mxd = arcpy.mapping.MapDocument(mxdDoc) layers = arcpy.mapping.ListLayers (mxd, "SURVEY_GRID_BNDRY") # Overwrite an existing file arcpy.env.overwriteOutput = True # Output directory for the pole maps outDir = r"G:\GEOSPATIAL\Publishing\Pole" # Set the workspace arcpy.env.workspace = outDir twpList = ['\"TOWNSHIP_C\" = \'D5\' AND \"RANGE_CD\" = \'7\'',\ '\"TOWNSHIP_C\" = \'D6\' AND \"RANGE_CD\" = \'7\''] for twpName in twpList: layers[0].definitionQuery = twpName print layers[0].definitionQuery # The final mapbook name taken from the list finalPDFfn = outDir + "\\" + twpName [16:18] + twpName [38:39] + "Pole.pdf" # Create the final PDF -- which is just an empty shell right now finalPDF = arcpy.mapping.PDFDocumentCreate(finalPDFfn) # A temporary pdf file for processing tmpPDF = outDir + "\\PoleMapPages.pdf" # Let the user know what is happening! print "Exporting " + twpName [16:18] + twpName [38:39] # Export the data driven pages in the mxd to a temporary PDF print "Exporting map pages to the temporary PDF" ddp = mxd.dataDrivenPages.exportToPDF(tmpPDF) # Append the temporary pdf to the final pdf # Cover, map pages, back cover print "Appending Map Pages" finalPDF.appendPages (r"G:\GEOSPATIAL\Publishing\Pole\PoleCovers\Covers_" + twpName [16:18] + twpName [38:39] + ".pdf") finalPDF.appendPages(tmpPDF) finalPDF.appendPages(r"G:\GEOSPATIAL\Publishing\TwpGrid_Color8x11.pdf") # Set properties for Adobe Reader and save PDF. finalPDF.updateDocProperties(pdf_open_view = "USE_THUMBS", pdf_layout = "SINGLE_PAGE") finalPDF.saveAndClose() # Clean up print "Cleaning up" # Delete the temporary PDF using the ArcPy function if arcpy.Exists(tmpPDF): arcpy.Delete_management(tmpPDF) # Delete objects del mxd, tmpPDF, ddp
