Python Error: arcpy.SelectLayerByLocation_management
2415
09-30-2016 04:52 AM
JerryGarcia
Occasional Contributor II
See screen shot.
Any suggestions?
Thanks!!!
import arcpy
wk=r'C:\Users\Administrator\AppData\Roaming\Esri\Desktop10.3\ArcCatalog\GIS DataCreator.sde'
arcpy.env.workspace=wk
print arcpy.env.workspace
fcCounties = "GIS.DATACREATOR.counties"
fieldsCounties = ['OBJECTID_1', 'Shape', 'NAME']
print arcpy.Exists(fcCounties)
fcSections = "GIS.DATACREATOR.sections_test"
fieldsSections = ['OBJECTID', 'Shape', 'county']
print arcpy.Exists(fcSections)
arcpy.MakeFeatureLayer_management(fcSections, 'sections_lyr')
arcpy.MakeFeatureLayer_management(fcCounties, 'counties_lyr')
with arcpy.da.SearchCursor('counties_lyr', fieldsCounties) as cursor:
for row in cursor:
print row[1]
arcpy.SelectLayerByLocation_management('sections_lyr', row[1])
Python 2.7.8 (default, Jun 30 2014, 16:08:48) [MSC v.1500 64 bit (AMD64)] on win32
Type "copyright", "credits" or "license()" for more information.
>>> ================================ RESTART ================================
C:\Users\Administrator\AppData\Roaming\ESRI\Desktop10.3\ArcCatalog\GIS DataCreator.sde
True
True
(-9645043.375313655, 3833831.999483527)
File "E:\Python\relateCopyCounties.py", line 23, in <module>
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\management.py", line 7359, in SelectLayerByLocation
raise e
RuntimeError: Object: Error in executing tool
FreddieGibson
Occasional Contributor III
Take a look at the example I sent in my previous message. Your problem is that you need to provide the 3rd parameter as a feature class or a geometry object. By default the da cursor will return geometry as a tuple. You will want to use the Shape@ token to have it return the geometry object.
Just to provide a little more detail I've also included my logic below.
# Example 1
geom = next(arcpy.da.SearchCursor("fnet", "SHAPE"))[0]
arcpy.management.SelectLayerByLocation("fnet", "INTERSECT", geom)
''' In the above example "SHAPE" returns (2124.3204345703125, 3.0001017252604063) '''
# Example 2
geom = next(arcpy.da.SearchCursor("fnet", "SHAPE@XY"))[0]
''' In the above example "SHAPE@XY" returns (2124.3204345703125, 3.0001017252604063) '''
# Example 3
geom = next(arcpy.da.SearchCursor("fnet", "SHAPE@"))[0]
''' In the above example "SHAPE@" returns <Polygon object at 0x2382fcf0[0x2382f3e0]> '''
In the above examples note what is returned from the cursor. If you were to run each of these expressions you'd not that only the third one works, whereas the first two return the following exception.
Runtime error
File "<string>", line 1, in <module>
File "c:\program files (x86)\arcgis\desktop10.4\arcpy\arcpy\management.py", line 7320, in SelectLayerByLocation
raise e
FreddieGibson
Take a look at the parameters for the tool.
Select Layer By Location
http://desktop.arcgis.com/en/arcmap/latest/tools/data-management-toolbox/select-layer-by-location.ht...
Note that the second parameter is "overlap_type" (e.g. INTERSECT, CONTAINS, etc.) and you're supplying row[1], which is a tuple representation of the geometry with the value (-9645043.375313655, 3833831.999483527).
JerryGarcia
Thanks.  I was messing around with the parameters.  This is a mistake.  I get the same error when adding {overlap_type}:
arcpy.SelectLayerByLocation_management('sections_lyr', 'INTERSECT', row[1])
FreddieGibson
# Example 1
# Example 2
# Example 3
Runtime error
raise e
JerryGarcia
THANKS!
