Python If Statements in Field Calculator
7456
11
03-11-2016 07:00 AM
DarrochKaye
Hello all,
I am trying to convert a nested IF statement from Excel into Python via the Field Calculator in ArcMap. The data is wind data which has two fields: U and V; and the calculation is to be entered in the DIR field. These are vectors can be applied with triganometry to create wind direction in degrees. In Excel, the DIR field has the following formula:
=IF(D2>0,((180/PI())*ATAN(C2/D2)+180),IF(AND(C2<0,D2<0),((180/PI())*ATAN(C2/D2)),IF(AND(C2>0,D2<0),((180/PI())*ATAN(C2/D2)+360),IF(AND(D2=0,C2>0),270,IF(AND(D2=0,C2<0),90,0)))))
...where column C is the U field and column D is the V field.
I've been playing all day with this and so far, I have the following:
codeblock:
def winddir(DIR):
    if !V! > 0:
        !DIR! = ((180/math.pi)*math.atan(!U!/!V!)+180)
    elif !U! < 0 and !V! < 0:
        !DIR! = ((180/math.pi)*math.atan(!U!/!V!))
    elif !U! > 0 and V < 0:
        !DIR! = ((180/math.pi)*math.atan(!U!/!V!)+360)
    elif !V! == 0 and !U! > 0:
        !DIR! = 270
    elif !V! == 0 and !U! < 0:
        !DIR! = 90
DIR =
winddir(DIR)
I keep getting the generic error:
ERROR 000989: Python syntax error: Parsing error SyntaxError: invalid syntax (line 2)
I'm really pulling my hair out with this as I've tried tweaking the syntax but I cannot resolve it. Any assistance would be greatly appreciated.
DK
JamalNUMAN
Legendary Contributor
Great. It works for me. Very much appreciated
["Extreme", "High", "Moderate", "Low", "Very Low"][!Value!-1]
Jamal Numan
LotharUlferts
New Contributor III
Because DIR doesnt appear in the winddir function , I removed the parameter in the def-statement.
I guess you're working in the python-window, so please try this:
arcpy.env.workspace= "A:\\test" # Change to the data source directory
tables = arcpy.ListFeatureClasses('*') #all shapes inside the directory
#ALTERNATIVE if tables wanted
# tables = arcpy.ListFiles('*.dbf') #all dBase-files inside the directory
len(tables) # just to controll, should be ~50
for table in tables: #loop through all files
    with arcpy.da.UpdateCursor(table,["DIR","U","V"]) as cursor:
        for row in cursor: #loop through all rows
            u,v = row[-2:]
            row[0] = winddir(u,v) #new DIR-value associated
            cursor.updateRow(row) #rewrite the row in the table
You can replace line 11&12  by this expression:
row[0] = winddir(*row[-2:])
