Python label expression adding text & fields
1238
07-06-2018 07:08 AM
DamonOsbourne
New Contributor II
Need python label expression to label linear assets in Arcmap 10.3 with length (rounded to nearest whole number) with a foot symbol(') at the end, plus a space, then text from a different field.  Have this so far: round(float( [LLENGTH]), 0)
DanPatterson_Retired
don't know about 10.3 or vb but in python and recent versions
leng = 7.4
fld = 'from field'
result = "{}' {}".format(round(leng), fld)
print(result)
7' from field
DamonOsbourne
New Contributor II
Thanks, I may have tagged the question incorrectly, looking for label expression syntax for the Maplex Label Engine in Arcmap
MitchHolley1
MVP Regular Contributor
Damon,
Dan has given the correct Python Label Expression in line 5 of his example.  The first variable will be the LENGTH field, and the second is whatever other text field you chose.
You may have to convert the length field to a float first (line 3).
"{}' {}".format(round(leng), fld)"{}' {}".format(round(float(leng)), fld)‍‍‍‍
DamonOsbourne
New Contributor II
Works great.  Thanks!
