I've written this code, and the expression checks out, but it only labels the first field. Can someone tell me why it doesn't run through the rest of the if's to create a stacked label with field >0?
def FindLabel ( [Light_Numb], [IN_FDN] , [IN_35_FT_METAL_POST] , [IN_35_5] , [IN_40_5] , [IN_6_FT_ARM] , [IN_12_FT_ARM] , [IN_18_FT_ARM] , [IN_X_ARM] , [IN_LED_87W_OH] , [IN_LED_101W_OH] , [IN_LED_110W_OH] , [IN_LED_260W_OH] , [IN_LED_87W_UG] , [IN_LED_101W_UG] , [IN_LED_110W_UG] , [IN_LED_260W_UG] , [IN_PC] , [IN_SC] , [CONC_WORK_REQ_SQ_FT] 😞
try:
if [Light_Numb] > 0:
return [Light_Numb]
'\n'
if [In_FDN] > 0:
return 'In FDN', [IN_FDN]
'\n'
if [IN_35_FT_METAL_POST] > 0:
return 'IN 35 FT METAL POST', [IN_35_FT_METAL_POST]
'\n'
if [IN_35_5] > 0:
return 'IN 35-5', [IN_35_5]
'\n'
if [IN_40_5] > 0:
return 'IN 40-5', [IN_40_5]
'\n'
if [IN_6_FT_ARM] > 0:
return 'IN 6 FT ARM', [IN_6_FT_ARM]
'\n'
if [IN_12_FT_ARM] > 0:
return 'IN 12 FT ARM', [IN_12_FT_ARM]
'\n'
if [IN_18_FT_ARM] > 0:
return 'IN_18 FT ARM', [IN_18_FT_ARM]
'\n'
if [IN_X_ARM] > 0:
return 'IN X ARM', [IN_X_ARM]
'\n'
if [IN_LED_87W_OH] > 0:
return 'IN LED 87W', [IN_LED_87W_OH]
'\n'
if [IN_LED_87W_UG] > 0:
return 'IN LED 87W', [IN_LED_87W_UG]
'\n'
if [IN_LED_101W_OH] > 0:
return 'IN LED 101W', [IN_LED_101W_OH]
'\n'
if [IN_LED_101W_UG] > 0:
return 'IN LED 101W', [IN_LED_101W_UG]
'\n'
if [IN_LED_110W_OH] > 0:
return 'IN LED 110W', [IN_LED_110W_OH]
'\n'
if [IN_LED_110W_UG] > 0:
return 'IN LED 110W', [IN_LED_110W_UG]
'\n'
if [IN_LED_260W_OH] > 0:
return 'IN LED 260W', [IN_LED_260W_OH]
'\n'
if [IN_LED_260W_UG] > 0:
return 'IN LED 260W', [IN_LED_260W_UG]
'\n'
if [IN_PC] > 0:
return 'IN PC', [IN_PC]
'\n'
if [IN_SC] > 0:
return 'IN SC', [IN_SC]
'\n'
if [CONC_WORK_REQ_SQ_FT] > 0:
return 'CONC WORK REQ SQFT', [CONC_WORK_REQ_SQ_FT]
except:
return 'None'
