Hi All,First off I'm new to Python coming from a Java/C++ background. I've created a simple Python program that will connect to a database and query it returning the results from the querys. I receive a nasty syntax error message which I cannot spot in my code. Maybe one of ye can? Im running Python 2.7 and MySQL 5.6. Wingware is the IDE I'm using on a Windows 8.1 OS.import MySQLdb
class Database:
host = "localhost"
user = "testuser"
passwd = "password"
db = "test"
def __init__(self):
self.connection = MySQLdb.connect(host = self.host,
user = self.user,
passwd = self.passwd,
db = self.db
def query(self, q):
cursor = self.connection.cursor(MySQLdb.cursors.DictCursor)
cursor.execute(q)
return cursor.fetchall()
def __del__(self):
self.connection.close()
if __name__ == "__main__":
db = Database()
q = "use test"
db.query(q)
q = "DELETE FROM testtable"
db.query(q)
q = """
INSERT INTO testtable
('name', 'age')
VALUES
('Mike',39),
('Michael',21),
('Angela', 21)
db.query(q)
q = """
SELECT * FROM testtable
WHERE age = 21
people = db.query(q)
for person in people:
print "Found: {0}".format(person['name'])
This is the error message:ProgrammingError: (1064, "You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ''name', 'age')\n VALUES\n ('Mike',39),\n ('Michael',21),\n ('Angela', 21' at line 2")Thanks in advance guys!Dave.
