Python: Output Dataset or Feature Class is same as input Input Dataset
3459
06-30-2015 07:23 AM
awei
New Contributor III
I want to project certain vectors in my folder so I wrote the following code. It gives me error message:
  File "F:/soil/python/code-project", line 34, in <module>
    arcpy.Project_management(infc, outfc, outCS)
  File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\management.py", line 8221, in Project
    raise e
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000670: output Output Dataset or Feature Class is same as input Input Dataset or Feature Class
Failed to execute (Project).
I'm pretty sure my input and output workspace is not the same. Here's the code:
import arcpy
import os
arcpy.env.workspace = "F:/soil/python"
outWorkspace = "D:/soil/project"
feature_classes = []
outCS = arcpy.SpatialReference()
outCS.factoryCode = 3174
outCS.create()
walk = arcpy.da.Walk(arcpy.env.workspace, datatype="FeatureClass", type="Polygon")
for dirpath, dirnames, filenames in walk:
        if "Subbasin" in filenames:
            filenames.remove('Subbasin')
        for filename in filenames:
            feature_classes.append(os.path.join(dirpath, filename))
print feature_classes
for infc in feature_classes:
    dsc = arcpy.Describe(infc)
    if dsc.spatialReference.Name == "Unknown":
        print('skipped this fc due to undefined coordinate system: ' + infc)
    else:
        # Determine the new output feature class path and name
        outfc = os.path.join(outWorkspace, infc)
        # project data
Thanks for any help!!!
TomSellsted
MVP Regular Contributor
a wei,
Do the coordinate systems have a different datum?  If so, it might be necessary to include a transform method in your parameters.
Regards,
Tom
JakeSkinner
Esri Esteemed Contributor
Hi Wei,
I think the problem is with how you are setting the outfc variable.  It looks like you are joining "D:/soil/project" to the full path of the infc.  I would add a print statement for the outfc.  I believe it's going to be:
D:\soil\project\F:\soil\python\[feature class]
awei
New Contributor III
It's not. It's the original location of the input file.
JakeSkinner
Try the following:
    infc = infc.split("\\")[-1]
    else:
        # project data
