Curtis:
What if I am running the python script from a Windows Server 2008 Scheduled Task? I do not believe I have the option of running the script in the background, as by default, the script runs in the foreground. As such, I thought geoprocessing at v10.1 can be run in the 64 bit environment, but if I cannot force the script to run in the background it will still run in the 32 bit environment.
So even though I have access to a 64 bit environment, I cannot make use of this environment with a scheduled task because it can only run in the foreground.
Am I correct with this assessment?
