I have a table in my geodatabase that contains fields with some values and empty fields.
What I am trying to do is first let the user select the table to use, then add values to 2 fields based on values in another field but I am a beginner with python so I was wondering if someone here knows what is wrong with my script.
Thank you
import arcpy
# Get table parameter
param1 = arcpy.Parameter(
displayname="Roads")
# Open table to edit
GeoDBLocation = open (param1, 'r+')
Fields["LABEL", "SYMBOL", "SYM_TYPE"]
# Add data
cur = arcpy.UpdateCursor(GeoDBLocation)
For row in cur:
If row.getvalue("LABEL") == "H":
row.setvalue("SYMBOL", "3.01")
row.setvalue("SYM_TYPE", "S")
Elif row.getvalue("LABEL") == "L":
row.setvalue("SYMBOL", "3.02")
row.setvalue("SYM_TYPE", "F")
Else:
row.setvalue("SYMBOL", "0.01")
row.setvalue("SYM_TYPE", "O")
cursor.updateRow(row)
#Delete cursor
del row
del cur
#close file
GeoDBLocation.close
