Python Tool class supported geometries
397
5
10-18-2011 03:17 AM
MarkCorbin
The Tool coumentation mentiones that only three types of shape are supported:
  1. Line
  2. Rectangle
  3. Circle
What about Point or Polygon gemetries? Is there any implicit or explicit way to get them?
Szymon Piskula
JasonPardy
Hi Szymon,
There is no specific shape for point or polygon.
To construct the point, you must use onMouseDown or onMouseDownMap. Using the x and y coordindates you can construct the point geometry.
pt_geom = arcpy.PointGeometry(arcpy.Point(x, y))
For polygon, we hope to include this for final. For now, you would need to use line and close it off. Here is an example:
class LineToPolyTool(object):
    """Implementation for LineToPoly_addin.linetopoly (Tool)"""
    def __init__(self):
        self.enabled = True
        self.cursor = 3
        self.shape = "Line"
    def onLine(self, line_geometry):
        array = arcpy.Array()
        part = line_geometry.getPart(0)
        for pt in part:
            print pt.X, pt.Y
            array.add(pt)
        array.add(line_geometry.firstPoint)
        polygon = arcpy.Polygon(array)
I hope this is helpful.
Jason Pardy
Esri
DanPatterson_Retired
Jason
could you throw your code within the code blocks in the HTML editor (ie # symbol after selecting your code)
BobBaker1
Does anyone know where we can get documention for the line_geometry object that onLine produces?
I am trying to simply create a line with onLine and turn it into a polyline.
Hi Szymon,
    def __init__(self):
        self.enabled = True
        self.cursor = 3
        self.shape = "Line"
        for pt in part:
            print pt.X, pt.Y
            array.add(pt)
Jason Pardy
Esri
JasonScheirer
It's just a Polyline object.
BobBaker1
I just realized that after I found the documentation. Thanks!
