I've got an Add-In (Dockpane) created with the .NET SDK for ArcGIS Pro, in which I'm executing a Python-toolbox. As long as I don't have to return a value into my .NET SDK, it works fine. But I'm stuck when I try to return a value, even just a string, from my python toolbox into the calling scope. Could anyone help me?
That's my python-script:
import arcpy
if arcpy.GetLogHistory():
arcpy.SetLogHistory(False)
if arcpy.GetLogMetadata():
arcpy.SetLogMetadata(False)
from tkinter import messagebox
from osgeo import gdal
import os
import ast
from arcpy.arcobjects import convertArcObjectToPythonObject
import sys
class Toolbox(object):
def __init__(self):
"""Define the toolbox (the name of the toolbox is the name of the
.pyt file)."""
self.label = "Toolbox"
self.alias = "toolbox"
# List of tool classes associated with this toolbox
self.tools = [ParcsVectors]
def load_vector():
try:
messagebox.showinfo(title="test", message="Hello - this message is from a TEST Python script")
return "test"
except Exception as err:
messagebox.showinfo(title="Load vectors failed", message="Exception: " + str(err))
class ParcsVectors(object):
def __init__(self):
"""Define the tool (tool name is the name of the class)."""
self.label = "ParcsVectors"
self.description = ""
def getParameterInfo(self):
"""Define parameter definitions"""
result = arcpy.Parameter(
displayName="Output Features",
name="out_features",
datatype="GPString",
parameterType="Required",
direction="Output")
params = [result]
return params
def isLicensed(self):
return True
def updateParameters(self, parameters):
return
def updateMessages(self, parameters):
return
def execute(self, parameters, messages):
# parameters[0] = load_vector()
result = load_vector()
messagebox.showinfo(title="testing", message= result)
arcpy.SetParameter(0, result)
return
The messagebox shows the correct result. But it is not returned to
var gpResult = Geoprocessing.ExecuteToolAsync(toolboxPath, null, null, null, null, GPExecuteToolFlags.AddToHistory);
gpResult.Wait();
what do I need to change in my python script, so that the return value is actually returned?
