I think it's an inconsistent indentation error. There are 11 red symbols. You are likely using 4 spaces as an indentation, meaning you should have 12 spaces for 4 levels of indentation.
Try adding one space and see if that solves it.
I used to get this issue quite often (I've now moved to PyScripter and haven't had this issue since).
The following always works for me. Highlight the "infected area" > right click > choose Source Code > then click Untabify Region.
Works every time for me. No idea what causes this, but it happened dozens of times over the years, while using many different PythonWin versions.
Will do. Thanks.
Now I am seeing another new thing! What in the world is this white circle next to one of my def()'s?
[ATTACH=CONFIG]34040[/ATTACH]
