I am using arcMap 10.1. I right click on the field I want to update, select field calculator, I select in the list box which attribute column header I want to use to populate the field. Once I click okay. It takes a few seconds, then crashes.
---No error
----I have about 5 editing when I am editing-Could this be the problem?
---Also If I select 100-200 records, then it populates. This has worked before, but now I have thousands of records to update.
