"Extract Data Task" fails when executing as a geoprocessing service
4582
01-30-2015 11:10 PM
DenishReghu
I am not able to execute the "Extract Data Task" model as a geoprocessing service from the server. From the server log I am getting the following
<Msg time='2015-01-30T16:39:10,797' type='SEVERE' code='20010' target='PSS/ExtractDataTaskAsync.GPServer' methodName='GPServerSync.CheckMessages' machine='BACKUPSERVER' process='17768' thread='15044' user='Admin' >updateParameters Execution Error: Runtime error
  File "c:\program files\arcgis\server\ArcToolbox\Toolboxes\Server Tools.tbx#ExtractData_server.UpdateParameters.py", line 3, in <module>
  File "c:\program files\arcgis\server\ArcToolbox\Toolboxes\Server Tools.tbx#ExtractData_server.UpdateParameters.py", line 7, in __init__
  File "c:\program files\arcgis\server\arcpy\arcpy\__init__.py", line 24, in <module>
    from arcpy.toolbox import *
  File "c:\program files\arcgis\server\arcpy\arcpy\toolbox.py", line 342, in <module>
    from management import Graph, GraphTemplate
  File "c:\program files\arcgis\server\arcpy\arcpy\management.py", line 22, in <module>
    import _management
  File "c:\program files\arcgis\server\arcpy\arcpy\_management.py", line 14, in <module>
    import _graph
  File "c:\program files\arcgis\server\arcpy\arcpy\_graph.py", line 27, in <module>
    import numpy
  File "C:\Python27\ArcGIS10.1\Lib\site-packages\numpy\__init__.py", line 137, in <module>
    import add_newdocs
  File "C:\Python27\ArcGIS10.1\Lib\site-packages\numpy\add_newdocs.py", line 9, in <module>
    from numpy.lib import add_newdoc
  File "C:\Python27\ArcGIS10.1\Lib\site-packages\numpy\lib\__init__.py", line 4, in <module>
    from type_check import *
  File "C:\Python27\ArcGIS10.1\Lib\site-packages\numpy\lib\type_check.py", line 8, in <module>
    import numpy.core.numeric as _nx
  File "C:\Python27\ArcGIS10.1\Lib\site-packages\numpy\core\__init__.py", line 5, in <module>
    import multiarray
ImportError: DLL load failed: %1 is not a valid Win32 application.
Any tips on how to resolve this?. Our ArcGIS Server version is 10.1. Also available 32 and 64 bit Python installation with the same machine.
DanPatterson_Retired
Numpy seems to have failed import.  it should be 32 bit as all other applications up the food chain
