Ok, I didn't think I would get away with that brief specification. A sample script takes 3 seconds to iterate 100 times. I have shown one case creating a layer of the random selection. You could put this back into a table of contents.# randomselection.py
# 19 May 2011
# kimo@ollivier.co.nz
# Input: parcel polygon featureclass
# item to sum (area)
# threshold (check min, mean, max values for reasonable figure)
# Assumes values always less than threshold or you get a null list
# Output: Total sum and layer with selected parcels
# set up to allow iteration
# uses ArcGIS 10 but could use 9.3
import arcpy
import sys
import os
import random
import datetime
try:
fc = sys.argv[1]
item = sys.argv[2]
threshold = sys.argv[3]
except:
# debugging and standalone operation
fc = "c:/project/forum/mobile.gdb/parcel"
item = "area"
threshold = 100000.0 # square metres
def getdict(fc,item):
''' Make a dictionary
once for the sampler
dParcel = {}
for row in arcpy.SearchCursor(fc,"featcode = 'parcel'"):
if item.lower() == 'area':
dParcel[row.objectid] = row.shape.area
else :
dParcel[row.objectid] = row.GetValue(item)
return dParcel
def getsample(dParcel,threshold):
'''Given a dict of values
return a random selection
less than the threshold.
Shuffles the list and pops off
the ids until threshold reached
ie sampling without replacement
total = 0
lstObj = []
lstKey = dParcel.keys()
random.shuffle(lstKey)
while total < threshold:
nObj = lstKey.pop()
nVal = dParcel[nObj]
total = nVal
if total > threshold:
break # do not exceed threshold
else :
lstObj.append(nObj)
total += nVal
return (total,lstObj)
# --------------- main ---------------
print
start = datetime.datetime.now()
print start
# make a dictionary
dParcel = getdict(fc,item)
print "records",len(dParcel)
# sample the dictionary
total,lstObj = getsample(dParcel,threshold)
print "Total: ",total
print "No of parcels: ",len(lstObj)
print "objectid: value"
for ob in lstObj:
print ob,":",dParcel[ob],", ",
print
# make up an sql query to select the features
sqlQuery = "OBJECTID in (" + ",".join([str(id) for id in lstObj]) + ")"
print sqlQuery
arcpy.MakeFeatureLayer_management(fc,"fc_lay",sqlQuery)
lyrName = arcpy.CreateUniqueName("xx.lyr",os.path.dirname(os.path.dirname(fc)))
print lyrName
arcpy.SaveToLayerFile_management("fc_lay",lyrName)
# Or sample the dictionary 100 times
for it in range(100):
print total,len(lstObj)
# finished
elapsed = datetime.datetime.now() - start
print "\n\nElapsed",elapsed, "Well done!" # positive feedback
2011-05-19 20:40:43.640000
records 7170
Total: 145316.242757
No of parcels: 21
objectid: value
726 : 809.726863177 , 4530 : 809.419546424 , 4752 : 1012.70775115 , 6120 : 809.397052955 , 3022 : 809.418725814 , 253 : 986.240771943 , 4445 : 1132.16238039 , 7161 : 928.75695316 , 5747 : 964.13873029 , 2188 : 864.834770195 , 4164 : 20.9192428737 , 187 : 839.573627519 , 2745 : 811.268061104 , 2572 : 1002.32513709 , 1445 : 1381.14243957 , 2674 : 812.661986759 , 6925 : 25126.7099296 , 5479 : 1395.56544711 , 4791 : 810.812432473 , 5406 : 848.317697436 , 6543 : 72658.1213786 ,
OBJECTID in (726,4530,4752,6120,3022,253,4445,7161,5747,2188,4164,187,2745,2572,1445,2674,6925,5479,4791,5406,6543)
c:/project/forum\xx0.lyr
185921.392647 4
145871.629063 27
154201.63183 1
140524.256299 0
190822.946912 9
193668.483773 23
334292.358346 16
141967.626185 23
15109126.1898 56
413536.709991 2
157130.891363 6
Elapsed 0:00:02.917000 Well done!
