I have written a python script that finds the mean of all pixel values in a raster. Once I get the mean (suppose 0.3 in this case), I can use raster calculator and assign pixel value of 1 to each pixel higher than the mean and 0 to everything else. The equation is as follows -
Float(Con("Raster1"<0.3, 0, 1))
However, there are 30 raster files, thus, I want to avoid manually using the Raster Calculator. I have added the following codes to the script-
Raster_mean = got from previous script [0.3 in this case]
arcpy.gp.RasterCalculator_sa('Float(Con("Raster1"<Raster_mean, 0, 1))' , "E:/ArcGIS Python/raster10")
I am getting the following errors-
NameError: name 'Raster_mean' is not defined. Failed to execute (RasterCalculator).
Seems like it does not take any predefined variable but only raw values. Is there any other option to conduct the task?
